Headunit lights went out... any ideas?
Old Dec 17, 2012 | 09:42 AM
FLASH1970's Avatar
The headunit on my car decided it didn't want to light up anymore. The display still works, but none of the buttons light up like it used to. Is there a bulb or LED somewhere in the headunit I can change? Thanks in advance for your help.
09 SS with the Pioneer sound system.
Flash
Old Dec 17, 2012 | 09:49 AM
MastaShaKe_88's Avatar
you can change the bubs... but that sounds weird if all of em went out at the same time tho
do your dash lights still work?
Last edited by MastaShaKe_88; Dec 17, 2012 at 09:49 AM. Reason: Automerged Doublepost
Old Dec 17, 2012 | 10:24 AM
FLASH1970's Avatar
Dash lights work. The Fog lights button, Traction button, cluster, Heat/AC controls... still light up ok. And the display in the headunit still works. It's just the buttons that aren't backlit anymore.
Old Dec 18, 2012 | 03:27 AM
EmperorJJ1's Avatar
i think ive herd of that as an issue before. if i remember correctly the newer modles have a face on them like the older ones that can be removed. you may want to remove it and try cleaning the surface that connects the 2 pieces and see if that helps. may need to replace it thou
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
tomj77
Oct 4, 2015 11:39 AM
Tupp
Sep 30, 2015 08:18 PM
