Hooking up to stock system
Old May 20, 2008 | 01:17 AM
MattCA's Avatar
My sister has left and forgot about these 2 10" sony explodes and an mdx amp. I remember it being an ok system and wouldnt mind just taking it. Can I use the wireing thats with the stock system? Or would I have to rewire it? Will it wire to the stock deck? Ive installed a few systems but I dont know if I want to be ripping up my car if I dont need to. Thanks.
-Matt
Old May 20, 2008 | 01:28 AM
jefferyss's Avatar
what is your make and model of car?
Old May 20, 2008 | 01:29 AM
balt21's Avatar
-Matt
i dont know if your talking about wiring into the stock sub in the SS/SC so i dont know about that. i would probably just disconnect it though and run the aftermaket subs. Yes, you can wire it to the stock deck. you need to get a line out converter. connect your RCA's to that and then splice the high levels into your speaker wire from the 6X9s. if the amp has high level inputs you can just splice those into the speaker wire and do not need the line out converter; that is how mine is set up.
Old May 20, 2008 | 02:00 AM
BlackMachine's Avatar
yea it will wire...but it WILL slow your car down...lol
Old May 20, 2008 | 03:19 PM
MattCA's Avatar
Its an 06 ss/sc. I would leave the stock sub in place but I would not connect it. I just want to throw in the two 10s and wire them to the amp. Im just wordering if I would have to complety rewire everything or if you can use any of the existing wires. It looks weird how they have it wired. Is there even an amp? Ugh kind of sounds like a headache. Slow it down? You mean weight wise right?
Old May 20, 2008 | 05:24 PM
balt21's Avatar
i dont know how the stock sub/amp is wired because i dont have a SS/SC, but i would assume you could reuse the existing wires as long as they are the correct gauge. make sure there is an inline fuse as well in between the battery and the amp. it would probably be easier to just get a wiring kit; that way you know you have everything you need. someone else may know about the SS/SC wiring though. hope that helped.
yea, i think that is what he meant by "slow it down" lol.
Old May 21, 2008 | 06:14 AM
EmperorJJ1's Avatar
line out convertor for signal and remote to the fuse box... everything else is a normal amp install except u can run the ground right to the battery
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Stuff
Oct 1, 2015 05:47 PM
