How anyone attempt this
Old Apr 2, 2009 | 02:31 AM
Cyrusthevirus's Avatar
How anyone cut the back panel to fit big 6x9's in the back?
I have a set of JBL t595 Limited speakers. They are rated at 150 rms and 300 peak. I have this mounted in my old camaro and im thinking about putting them in the balt.
Old Apr 2, 2009 | 09:42 AM
Maetrix's Avatar
6x9
Aren't the factory speakers 6x9's?
They are rear mounted, just lose the grilles and you should be fine.
Somebody, correct me if I am wrong, because I often am.
Old Apr 2, 2009 | 12:15 PM
stinkyfisherman's Avatar
The rear deck is 6x9 but not all 6x9's will fit. You can cut it to make it bigger I'd use an air saw, metal shears or something.
Old Apr 2, 2009 | 11:46 PM
the grills dont come off they are made that way
Old Apr 2, 2009 | 11:52 PM
KyleMinnis's Avatar
the grill wont even be seen...
Old Apr 3, 2009 | 08:56 PM
SS SCHGD's Avatar
should fit just fine under the rear deck cover. Might push it up a bit in that space, but will likely keep the cardboard panel (fiberboard or whatever it is) from rattling after you break of a clip (which your about gaurenteed to do, Lol) I put the grills on my 6.5 components and a 3/4 inch spacer and it only pushes up a tiny bit.
Old Apr 4, 2009 | 02:41 AM
EmperorJJ1's Avatar
you can cut it or just screw it in sorta half way. since the rear deck isnt even close to being sealed off even partially you wont notice a difference in sound
Bluelightning
Nov 11, 2015 02:41 PM
Wind
Sep 11, 2015 06:57 PM
BlackSS05
Jul 9, 2006 08:24 PM
TXRLU
Apr 10, 2006 03:57 PM
