How to get better sound - bypass fact amp?
Old Jun 23, 2009 | 03:46 AM
250motorsportz's Avatar
Hey guys, I recently put in a Pioneer 7" double din and a 12" JL W3. My speakers are being double amped now (by the headunit and factory amp). What is the easiest way to allow my headunit to amp the speakers and NOT the factory amp? I don't want to do the "Factory Amp Bypass" because I would not like to run a aftermarket amp to amplify my speakers. Thanks!
Old Jun 23, 2009 | 06:53 AM
Spun's Avatar
If you have a 07 or newer SS or SS/SC/TC then you shouldn't be double amping it. If you used an expensive harness then it converts the low signal that runs to the amp into RCA's so they can interface with the aftermarket deck.
Can't really help untill I know what your running (harness, year make of car, stock Pioneer sytem or base sytem)
Old Jun 23, 2009 | 10:47 PM
ctcsoccer7's Avatar
i would have to agree.....plus you would be the first person i know of that has double amped speakers , from your pioneer system , and factory radio. my guess is your just intergrated into the factory amp!
Old Jun 24, 2009 | 02:18 AM
EmperorJJ1's Avatar
lol double amping it isnt the term i would use but tis very possible.... let us know those 4 things spun asked and how high the volume is when your normally listing to it
Old Jun 24, 2009 | 02:38 AM
its a 2005. and I used a PAC (dont remember the exact model). Double amping probably isnt the word but it gets really distorted after about Volume level 15. I usually listen to it at about 10-13 which isnt cranked but is decent. I like to have my music loud and clear though. Anyone know whats going on here or how I can fix this?
Old Jun 24, 2009 | 03:21 AM
Spun's Avatar
Is it a SS/SC with the Pioneer system (sub in the trunk, tweeters in the sail panels)
How much did the PAC run you, was it like $20 or like $150.
2005, Canadian, so it doesn't have Onstar then right.
Old Jun 24, 2009 | 04:21 AM
EmperorJJ1's Avatar
ya the pac is sorta a waste... but i know what your talking about and its a weird fix. Bet thing to do is use the rca outputs on the deck. If you can find some rcas that have seperate wires for pos and neg it would be best but if not just buy some cheap rcas and cut them. the outer shielding is neg and inner core is pos
probably like 100 spun. its the half ass module for us 05-06 guys but it doesn't really do anything other then give you acc. personally id rather save the 80 bucks and run a wire but whatever
Old Jun 24, 2009 | 04:26 AM
musifreak190's Avatar
run new wires to the speakers lol or find the stock amp and wire the in and the output harness together which is dumb, run fresh wire and mine as well pick up a nice alpine 4 channel amp with some new infinite speakers
Old Jun 25, 2009 | 02:16 AM
Yeah its a SS/SC with Pioneer, sorry should have made that clear earlier. The pac was $120 (with my discount) reg price like $220+!
Yes, it has Onstar.
Emperor, I have no idea what you are talking about! Lol, could you please clarify?
Old Jun 25, 2009 | 03:11 AM
EmperorJJ1's Avatar
does ur pac unit have rcas?
pics of the harness
Old Jun 26, 2009 | 06:27 AM
No it doesnt. Just straight two plug ins for the harnesses, the factory one comes in, aftermarket goes out and wired to the back of the deck.
Old Jun 26, 2009 | 09:49 AM
EmperorJJ1's Avatar
thats why... your giving the factory amp too much input power. you need to get it to rcas some how. the splicing of rcas like i explained earlier is a bit ghetto but it will work
Old Jun 28, 2009 | 01:28 AM
And that would fix the problems with the speakers being distorted too? What if I was to just unplug and remove my factory sub?
Old Jun 28, 2009 | 01:53 AM
EmperorJJ1's Avatar
nope need the rca thing
Old Jun 28, 2009 | 01:00 PM
ctcsoccer7's Avatar
yeah if you dont do the rca thing , your gonna fry your factory AMP, just got done fixing one for a customer who did just that!
Old Jun 29, 2009 | 03:30 AM
Could i unplug my factory amp, splice into my speaker wires running to that fact amp and run new wires from there to the deck? And leave my fact amp unplugged? this way I could put in the stock HU and plug in my factory amp when I decide to sell the car?
Old Jun 29, 2009 | 05:01 AM
EmperorJJ1's Avatar
ya but a whole slew of issues are involved with that. trust me the rca thing will be the easiest and best especially if your expecting to sell the car later on
Old Jun 29, 2009 | 01:16 PM
Could you explain the rca thing a little better? Where do I run the rca' from and where do they go to?
Old Jun 29, 2009 | 07:25 PM
I've done tons of simple system and deck installs and I'm sure I can do this, but just dont know exactly what you are telling me to do?
Old Jun 29, 2009 | 08:05 PM
ctcsoccer7's Avatar
he is basically telling you to take your harness that has white,gray,green,and purple coming from the factory side and put rca ends on them, i have them where i work (bestbuy) the model number is rca8, this will power the factory amp, and in-turn the wires coming out of the aftermarket radio (same colors as above W,G,GR, P) will not be used you will just need to wire up power!
Old Jun 29, 2009 | 10:55 PM
EmperorJJ1's Avatar
who makes that btw? mtx makes exactly what he needs as an accessory for the jackhammer amps but you cant buy them separately
Old Jun 29, 2009 | 11:00 PM
Could you post a link of the rca8? i cant find it!
What has everyone else done? Is everyone thats running a aftermarket deck also running a aftermarket amp for their speakers?
Last edited by 250motorsportz; Jun 29, 2009 at 11:00 PM. Reason: Automerged Doublepost
Old Jun 30, 2009 | 11:25 AM
ctcsoccer7's Avatar
AAMP of AMERICA
comes color coded as well, W,G,GREEN,P
Old Jun 30, 2009 | 03:58 PM
http://www.beachaudio.com/AAMP-Of-Am...-p-139050.html
Is that what I need?
Old Jun 30, 2009 | 08:50 PM
ctcsoccer7's Avatar
um no, dude are you even reading what we write? RCA to WIRE! no box , no module, rca to wire!
you can take some rcas and cut the rca end off leaving some slack to work with, when you strip the cut end yo should have two wires one positive and one negative! you need a total of 4 ends + and -
Last edited by ctcsoccer7; Jun 30, 2009 at 08:50 PM. Reason: Automerged Doublepost
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
c_m_shooter
Sep 27, 2015 04:40 PM
