ignition controlled door locks
Old Jun 4, 2008 | 12:58 PM
YellowCobaltLT's Avatar
hi guys i have a 07 lt, manual trans, i am wondering if there is a way to turn off the ignition controlled door locks? thanks in advance
Old Jun 4, 2008 | 12:59 PM
chipsgt's Avatar
I think you can through the DIC.
You should check your owners manual.
Old Jun 4, 2008 | 03:03 PM
i have checked and wnet through the dic, no luck, thanks though
Old Jun 5, 2008 | 01:06 PM
Old Jun 5, 2008 | 01:09 PM
mkulrey13's Avatar
you cannot. At least no one has that is.
Old Jun 5, 2008 | 01:13 PM
bshoe421's Avatar
i think if you hold the information and reset button at the same time while parked that is one of the options but im not 100% on that.
Old Jun 5, 2008 | 05:52 PM
tried it no option for it on the manual trans version
Old Jun 6, 2008 | 08:30 AM
Old Jun 6, 2008 | 08:51 AM
OrngBalt's Avatar
can I ask why? Is there a reason you would want the doors open when driving?
Old Jun 9, 2008 | 01:12 PM
I installed a compustar remote start made for a manual trans, when i take the key out of the ignition the car stays running therefore it does not unlock the doors, i have to push the unlock button on the door to get out, then close the door and then the car shuts down and the alarm arms and locks the doors
Old Jun 9, 2008 | 02:23 PM
raptors_67's Avatar
then you installed your compustar improperly or have not set the options for it properly. FYI it states directly in the owners manual how to disable locking on vehicle movement over 5mph. If you are still unable to find it I will find the procedure as I disabled mine the day I picked the car up. I also have a compustar 2 way FM starter/alarm and have no issues with it locking the doors before exiting the vehicle.
Old Jun 9, 2008 | 02:27 PM
Kibosh3's Avatar
i also have a compustar w/ the same issue...or if my car is running, and i step out of the vehicle and close the doors, the locks will close automatically...
Old Jun 9, 2008 | 03:17 PM
raptors if you can find it would be great--thanks
Old Jun 9, 2008 | 03:48 PM
Doc's Avatar
Doc
The dealership can use the TECH2 to make the changes you want.
Old Jun 10, 2008 | 01:32 AM
raptors_67's Avatar
I guess i should clarify with you first. Are you looking for the cars factory controlled ignition doorlocks or the compustars? I have access to both....
Old Jun 10, 2008 | 08:43 AM
the cars options, it is a manual trans...
Old Jun 11, 2008 | 08:33 AM
i just read through my owners manual and it says that the 5mph auto lock feature cannot be disabled
Old Sep 22, 2008 | 01:34 PM
daedlus's Avatar
did you ever get a resolution to this question? I am having the same issues...
agentirons
Oct 16, 2015 02:11 AM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Trav3480
Sep 28, 2015 02:46 PM
Coballin13
Sep 25, 2015 08:43 AM
