Installing new H/U in my 07.. Couple questions..
Old Dec 11, 2008 | 01:18 AM
RedEcotecSS's Avatar
Just read the FAQ and it made me have a couple questions..
The audio place I went to for the harness ordered me something called (directly from reciept) "Perphrial lan 11 bit adapter w/ onstar" .. I am installed a double din H/U (kenwood) and they ordered me a double din too "BKGMK350 07 gm/chevy double din kit"
Do I need an antenna adapter? Or should my radio already have one?
The harness was $170. ******* expensive **** so it better work! Is this the one I need? If not, he better keep looking cause I paid him a down payment of $90 cause I wasn't sure if it was the right one or not but he seemed sure. Figured I'd ask you guys.
Old Dec 11, 2008 | 01:25 AM
scottyguy401's Avatar
I had to buy an antenna adapter for my avic. I don't know about yours though. Also I paid 110 for my wiring harness, the lan04 or whatever it's called
Old Dec 11, 2008 | 01:45 AM
how much was your antenna adapter?
these wiring harnesses are outrageous. all my friends paid like 20 bucks for their harnesses! haha
bump before bed
Last edited by RedEcotecSS; Dec 11, 2008 at 01:45 AM. Reason: Automerged Doublepost
Old Dec 11, 2008 | 02:52 AM
Spun's Avatar
The GM antenna adapter does not work with the 07's
It did not work with mine, however I had the Pioneer system with XM.
What did work for mine was the Chrysler ant. adapter (go figure)
You can pick up the Scocshe or whatever the hell its call Chrysler ant. adapter at Walmart for (I can't remember the exact price) like $5.00 give or take a buck or two.
The Metra part # for the adapter is in the general Stereo FAQ, section, its just as cheap, the antenna adapters are not like the wire harness, there all pretty cheap.
I had to use a GMOS LAN 04 as well but when I got mine it was still uncertain which one to use, Ebay wasn't selling them at all. I had to go through a local shop and I paid like $200 Canadian for it. (plus tax, which BTW is 15% up here in Canada)
So $110 or $170 is a good deal in my eyes
Old Dec 11, 2008 | 08:24 AM
Thanks a lot for your input, Spun. I'll definitely get that adapter for the antenna at walmart then. $5 sounds like my kind of price. Haha.
Did you install a double din unit in your car? I just wanted to make sure that you have to purchase the double din dash kit before installing a aftermarket radio, right? Thanks again man.
Old Dec 12, 2008 | 12:31 AM
bump anyone else have any input?
Old Dec 12, 2008 | 12:38 AM
Yeah, you need the kit other wise your radio wont be mounted and will probably slide out when you accelerate
Old Dec 12, 2008 | 12:41 AM
figured so. considering the stocker bolts in.
Old Dec 12, 2008 | 03:45 AM
Spun's Avatar
Yea the kit is a must.
I went with the ISO mount rather than using the metal sleve that come with the decks.
The ISO allows you to bolt the unit right to the sides of the kit and then the kit bolts into the same spot that the stock HU does. Makes it nice and snug fitting in there.
BTW- All of the kits come with the hardware to do it ISO style, just incase I complicated things a little more, not to worry.
Old Dec 12, 2008 | 03:55 AM
raptors_67's Avatar
The harness is also necessary unfortunately. The 07's required an interface to properly communicate with the GM LAN system. It is possible to do without that harness but it's the right way to do it.
Old Dec 12, 2008 | 04:13 AM
EmperorJJ1's Avatar
looks like everything is all covered. Just fy for spun all the new GMs use the chrysler ant adapter. Sad thing is most have the normal motorola one in them somewhere and convert to that bullshit. Just so you have to convert back
Old Dec 12, 2008 | 09:21 AM
so i just gotta get the chrysler antenna adapter from walmart and im ready to go? hopefully my wiring harness comes in today.
Old Dec 13, 2008 | 03:26 AM
EmperorJJ1's Avatar
yes.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
