Lo Beams / Fog lights not working
Old Sep 22, 2014 | 09:51 AM
jojomexi's Avatar
Hello everyone! I recently noticed both my Lo beams and fog lights do not work. The high beams DO work. I am running HID's in both my low beams and fogs. Both L/R Hi/Lo beam fuses are fine. The DRL fuse was blown, replaced with a new 10V fuse, though didn't fix the issue. The headlight switch clicks/works, as i can hear the sound in the engine when i try to turn them on manually. When I hit the fog button, my side amber lights come on, but no fogs. I recently read that if you are running HID's you need to pull your DRL fuse or you can risk burning out your stock wiring.
Anything else I can check before I take it to my mechanic to attempt replacing the wiring? Thanks .
Old Sep 22, 2014 | 09:53 AM
blueLNFftw's Avatar
Yea, take them out and put in stock/halogen bulbs.
could be ballasts.
Old Feb 15, 2021 | 12:48 AM
Kj Fingal's Avatar
What do the headlights noises sound like coming out of an engine?🤔
Old Feb 15, 2021 | 10:00 AM
You joined just to comment on a 6.5 year old two post thread?
But you pointed out a work the OP missed, bay. Engine bay, the ballast make a humming noise and you can hear a relay click on some of the kits.
jc70nova
Nov 28, 2015 05:58 PM
Ramsdellb
Jan 24, 2013 03:20 AM
maassizzle
Jan 7, 2012 09:29 PM
steven2008ss
Feb 22, 2010 08:02 PM
ViSiONZ
Jul 10, 2009 08:00 PM
