My sound system and its progress.
Old 02-21-2012, 01:13 PM
Ccadet02's Avatar
Let me just start of by saying it grinds my gears to see wires and seams. The following is my sound system in progress that was designed to have minimal seams and wires.
Here is the frame I built for my 2 12" pioneer shallow mount subwoofers. There is a total of 4 layers of fiberglass. The first layer is grill cloth and resin the 2nd layer is fiberglass mesh strips the 3rd is fiberglas mat strips. The 4th layer is on solid sheet of fiberglass mesh. I plan on putting sound proofing in the box it self.
This is what it looks like in the car after bondo.
I took out all the carpeting in the trunk and used the cavity to make this for the driver side for the subwoofer amplifier and capacitor. Still needs some bondo work to close up the seams a little.
I did the same thing for the passenger side for the speakers amplifier and its crossovers. Also needs dondo for the seams.
For the floor of the trunk it will be made in 2 peices. The first peice will go around the spare tire well and touch all the enclosures. The second peice will go over the spare tire well and will be able to be taken out when needed to get to the spare tire. Everything will be carpeted with the same color as the stock color carpet. I like a stock, clean, streemline look. Paint would look bad a$$, I just cant see it for this project. For the black plastic peice that goes over the bottom trunk latch I plan on sand all the knobs off it and skin it with carbon fiber, not vinyl but real carbon fiber.
This is were I moved my Ipod/Iphone. I had my Ipod in the conpartment in the dash on the left hand side of the steering wheel. For a while it was bothering me there so I decided to move it. I cut the USB end off and drilled a hole just big enough for the wire to fit, then spliced it with a longer USB cable. I want to clean this up a little but no ideas come to mind yet. Im open to suggestions.
UPDATE!! 7 MAR 2012!
Subwoofer box is carpeted. i left extra carpet on to bring the carpet up over the hump that was above my box and to cut the carpet around the wheel wells.
The subwoofer box and the mount for the 4channel amp and crossovers are to seperate pieces but with the seams all closed up and carpet on it looks like one piece.
Tight up against the plastic piece no seams.
UPDATE 15MAR12!
this is the first part of the floor. i still need to add the lip that goes around the inside to the removeable peice can sit flush with the floor but i cant do that untill i carpet my subwoofer amp mount.
Old 02-24-2012, 09:05 PM
1LoudAssChevy's Avatar
nice...good luck and post final pics
Old 02-24-2012, 09:26 PM
C_A_D88's Avatar
Almost the same as mine
Old 02-24-2012, 09:28 PM
C_A_D88's Avatar
Old 02-25-2012, 11:19 PM
now just make you some of these LOL
or put this behind your rear seat
just felt like sharing
Last edited by 1LoudAssChevy; 02-25-2012 at 11:19 PM. Reason: Automerged Doublepost
Old 02-26-2012, 06:39 AM
C_A_D88's Avatar
.... That's just to much lol,
Old 02-27-2012, 12:41 AM
nah not even lmao i just like my music (((LOUD)))
Old 02-27-2012, 07:56 AM
Ccadet02's Avatar
to be honest i will only be pushing out 600 wats. i like a nice clean sound through out.
Old 03-09-2012, 02:56 AM
EmperorJJ1's Avatar
idk whos is crazier chevy urs or mine
Old 03-09-2012, 08:09 AM
Ccadet02's Avatar
mine is just for a clean look. i dont expect mine to be loud. i tune everything pretty well it will just sound good and clear.
Old 03-09-2012, 11:38 AM
EmperorJJ1's Avatar
yup the only thing i would have changed is facing the subs into the cab vs back but ya it looks damn clean
Old 03-09-2012, 12:48 PM
Ccadet02's Avatar
i originally thought about doing that but just liked this better to show off every thing. and thanx.
Old 03-09-2012, 01:57 PM
FasterIsBetter's Avatar
Yea, Id say his is crazier, or rather just plain stupid crazy...
Old 03-09-2012, 02:01 PM
Cadet, if I were to change anything, I would have tilted the subs back a lil at the top. This will reduce trunk rattle to a minimum. I tested it with my tilted trunk box and then went to a regular box. I am dynamatted as well.
Old 03-09-2012, 11:50 PM
EmperorJJ1's Avatar
true but looks<sound at least for me but everything came out really clean on ur install bro
Old 03-10-2012, 07:20 PM
Ccadet02's Avatar
iv had a subwoofer in my trunk before and not rattle due to the dynomate. they are angled just cant see it in the pic, but they are tilted in towards the center. plus i am not going to have much power goin threw them 600 RMS even then i will be turning the gain down on the amp.
Old 03-10-2012, 09:43 PM
LOL whose is crazier?
Old 03-10-2012, 09:58 PM
Ah, gotcha. I have more than that pushing through my subs but mine doesn't look that nice. I just have 2 Kicker CVR 12s in the kicker box. It looks alright with the carbon fiber design on the front of the box but yours blends in very nicely with the trunk.
Old 03-12-2012, 11:01 AM
Ccadet02's Avatar
Ishould have the floor in by this weekend.
Old 03-14-2012, 02:33 AM
EmperorJJ1's Avatar
what are u doing for the floor? spare still going to be functional?
Old 03-14-2012, 12:17 PM
Ccadet02's Avatar
yes the spare will be functional. its going to be a 2 part floor the first part will go from the amp mounts and subwoofer box to the beginning of the wheel well. the second will be a faulse floor were i can lift this peice out to get to the spare and bat. not will this only tie in the look but also has 100% function. i am still able to fit a lot inside this trunk.
01-12-2016 12:01 AM
biniecki
10-25-2015 02:23 PM
jimbofug007
10-02-2015 12:06 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
Quick Reply: My sound system and its progress.
