navi install
Old Oct 24, 2006 | 02:09 AM
senior_brown's Avatar
Canada navi install
hey everyone, dont know how many ppl have the avic d2, i was wondering if anyone that did hooked up the speed sensor wire and was it a pain in the butt? can the ebrake sensor just be grounded like anyother deck as well?
Old Oct 24, 2006 | 02:18 AM
c0baltic's Avatar
hmm look for a bypass for it.. i have it on my car so that i can have my passengers watch tv while i dirve and so i can adjust my equalizer with out having to put my e-brake on
-drew
Old Oct 24, 2006 | 02:20 AM
thats how i did it on every other deck i installed, but i really wanna know about the speed sensor wire, if anyone knows
Old Oct 24, 2006 | 02:38 PM
sunrise_mj's Avatar
speed sensor wire isnt ness. on Pioneer nav screens. itll work off GPS... and as for bypassing its gonna be more than just grounding the wire...
Old Oct 28, 2006 | 01:57 PM
xtremeGM's Avatar
True but I find that on my avic d1 (given mine is older) it is more accurate with the speed pulse wire. I had problems where in some areas it would get confused before I had the speed pulse connected. Its really not hard to do all I did is take apart the spedometer cluster and got the speed wire there which I believe was a green wire with a white stripe.
Old Oct 28, 2006 | 02:26 PM
i'll check it out as soon as i get mine, thanks,
Old Oct 29, 2006 | 12:42 AM
iLLmaTic3s's Avatar
the way to bypass is..u have to install a switch on the ebrake wire. one hooks on to the wire and the other goes to ground. also there is a open whole in the radio harness. insert a ground wire in there and...boom bypassed. i think this works with the d2. i know it does for the d1. its really the same thing...u mite not have to put a switch on the ebrake wire...just ground thoe 2 things mite just do the job.
Old Oct 29, 2006 | 01:13 AM
xtremeGM's Avatar
Yeah on the d1 all you have to do is ground the ebrake wire. I would assume the d2 is the same.
Old Oct 29, 2006 | 02:57 AM
ok, so its the same as my other deck, cool, im gonna hate taking my cluster of to get the speed pulse wire,
Old Oct 29, 2006 | 09:49 AM
iLLmaTic3s's Avatar
you are acutally going to do that...have fun with that. i never hook up that speed sense wire. the GPS always picks it up anyway...but have fun.
Old Oct 29, 2006 | 10:06 AM
xtremeGM's Avatar
Yeah, but its the easiest way. It's really not that hard at all
Old Oct 29, 2006 | 10:35 PM
iLLmaTic3s's Avatar
yeah on car is easy to take apart the gauges..on other cars...like some newer mercedes n ****...not fun...been there done that...**** sucked...so now im lazy when it comes to that..lol
Old Oct 29, 2006 | 10:37 PM
well i've taken my grand am apart about 50x, and it was easy, the thing i dont wanna do is have it loose when its back in, when i took the dash trim panels off to install my deck, i put them back on and they were a lil loose, i wanna get them factory tight again cause it pisses me off :| no one notices but me, but even then, if i notice it and dont like it that way, i wanna fix it, any ideas anyone?
Old Oct 30, 2006 | 07:26 AM
iLLmaTic3s's Avatar
well im not to sure how ours comes over. GM used mostly clips to hold in everything dashboard wise. so if its that case....use new ones.
Old Oct 30, 2006 | 03:29 PM
xtremeGM's Avatar
I had a 2004 Grand Am GT1 coupe before my Cobalt SS/SC and its just as easy as the Grand Am. New clips will fix the issue of the pieces being loose.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
