need help installing amp kit
Hey guys im going to be installing an amp kit and sub today..i.wanted to know where i can pass the battery cable through.and also where to connect my ground in the trunk..i also want a place to hide the cables so it wont look ugly..if you guys can give me a few pointers i would appreciate it.thanks
The battery is in the trunk, under the carpet so I'm not sure I understand where you're trying to go with the wires. Since it's right there you may as well just run both the positive and negative wires to the battery. Use a fuse on the positive wire, within say one foot of the battery terminal.
You can also use a seatbelt bolt as a grounding spot if you'd rather. Just scrape some paint off the surrounding area for a good connection.
How is the seat belt bolt a **** grounding spot? In quite a few vehicles that's what I've used and had no problems. Not trying to pick a fight man, I was just curious about why you say that.
As stated though, the battery is right there so just use that.
bc in general the seat belt bolt goes thru a nut thats spot welded to the chassis and with a large bolt like that it makes it much more difficult to get a proper connection as well. i mean it works but not as well as a sanded piece of sheet metal that's not "attached"
i totally agree and luckilly cobalts with the batt in the trunk make it easier... you dont have to drill just run to the battery and done. but remember a new batt terminal will be helpful
Sep 28, 2015 12:51 PM
