need help installing amp kit
Old Sep 7, 2011 | 09:26 PM
bayareacobaltss's Avatar
Hey guys im going to be installing an amp kit and sub today..i.wanted to know where i can pass the battery cable through.and also where to connect my ground in the trunk..i also want a place to hide the cables so it wont look ugly..if you guys can give me a few pointers i would appreciate it.thanks
Old Sep 7, 2011 | 09:51 PM
wjsigo's Avatar
The battery is in the trunk, under the carpet so I'm not sure I understand where you're trying to go with the wires. Since it's right there you may as well just run both the positive and negative wires to the battery. Use a fuse on the positive wire, within say one foot of the battery terminal.
You can also use a seatbelt bolt as a grounding spot if you'd rather. Just scrape some paint off the surrounding area for a good connection.
Old Sep 7, 2011 | 10:10 PM
Oh really? I had no idea the battery was in the trunk lol...i would just need to.pass the remote wire to the front
Old Sep 8, 2011 | 06:58 AM
EmperorJJ1's Avatar
seat belt bolt is a **** ground btw
Old Sep 8, 2011 | 07:04 AM
1LowLS's Avatar
I bolted my ground to my ass since its pretty grounded imo. Emp!Wheres the best place for amp ground?
Old Sep 8, 2011 | 12:22 PM
c4w18's Avatar
Let your multimeter do the talking for the best spot to ground...it depends on your amps location...
Old Sep 8, 2011 | 04:05 PM
EmperorJJ1's Avatar
^^ this or just ground the amp to the battery
Old Sep 15, 2011 | 04:08 PM
wjsigo's Avatar
How is the seat belt bolt a **** grounding spot? In quite a few vehicles that's what I've used and had no problems. Not trying to pick a fight man, I was just curious about why you say that.
As stated though, the battery is right there so just use that.
Old Sep 15, 2011 | 04:39 PM
EmperorJJ1's Avatar
bc in general the seat belt bolt goes thru a nut thats spot welded to the chassis and with a large bolt like that it makes it much more difficult to get a proper connection as well. i mean it works but not as well as a sanded piece of sheet metal that's not "attached"
Old Sep 15, 2011 | 08:07 PM
wjsigo's Avatar
Good point. I've just always hated drilling holes in my cars/trucks, and tried to use what was already there.
Old Sep 15, 2011 | 08:14 PM
EmperorJJ1's Avatar
i totally agree and luckilly cobalts with the batt in the trunk make it easier... you dont have to drill just run to the battery and done. but remember a new batt terminal will be helpful
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 28, 2015 12:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
