New battery not helping
The system right now is only at 1,000 watts (2 alpine type R's 12 inch 4-ohm subs with two alpine mrp500 amps for each) but I will be adding around 600 watts to it later, so the system will be b/t 1600-1700 watts
Ok so I upgraded my battery to a HC1800 from Kinetiks, and my lights still dim. What do you guys recommend that I do next? (Big 3, H/O Alt etc)
lol did you make sure the connections were frayed and loose for the extra resistance as well?
lol its ok drink one for me bro
Last edited by EmperorJJ1; Nov 15, 2009 at 03:49 AM. Reason: Automerged Doublepost
look into a larger wire from the under hood fuse block to battery. i tested my 09's alternator to put out 184 amps when warm so im sure most of us watt 2000 watt and less Rms suuld be fine on a stock alt with proper wire upgrades.
i wouldnt put 16-1700rms into type r's, and theres only like 3 people on this site with the big 3 done but its a cheap way to help with voltage drops. i dobut you need a H/O alt though. you could also get HID's becuase they dont dim....just cause your lights are dimming dosent mean something is necessarly wrong though.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
