One touch switch for passenger window?
Old May 17, 2009 | 03:53 AM
kidcrash603's Avatar
Can it be done?
Any chance it's as simple as just buying another drivers window switch and hooking it to the passenger wires?
Anybody done it?
Old May 17, 2009 | 10:46 AM
Erod's Avatar
Moderator Alumni
pls read
https://www.cobaltss.net/forums/announcement.php?f=68
moved
Old May 18, 2009 | 01:18 AM
EmperorJJ1's Avatar
no its implausible you would need quite a bit of work to even attempt to get it to work
Old May 18, 2009 | 12:35 PM
Why?
Is the passenger motor different from the drivers? It seems plausible that it could be accomplished with a switch change.
I'm gonna take a good look when I pull my door panels off to paint, but was hoping maybe someone had thought of this or tried it first...
Old May 18, 2009 | 12:38 PM
SilverSSedan's Avatar
Humm.. i dont know how it works in there, but i'm sure theres a switch somewhere letting the switch know when the window is the whole way down.. let us know if u get it figured out
Old May 18, 2009 | 12:46 PM
NCC-2000's Avatar
The driver switch and passenger switch for the driver's door is all one unit, they can't be separated so you'll have a hell of a time getting the passenger switch to work like the drivers.
Old May 18, 2009 | 12:51 PM
koch1ar's Avatar
i know that in my thunderbird, there was a >$10 module that you just spiced into 2-4 wires. I had auto driver down, i could've bought that part and had auto pass. unlike the guy above me the t-birds untits were seperate. Since no one has done it yet, i would have to say that it's nearly inpossible on our cars
Old May 18, 2009 | 03:56 PM
DaBuzzard's Avatar
The trick is not in the switch, it's in the bcm.
Not sure if the motor has a limit switch in it or if the bcm just senses the current getting too high when the window bottoms out but short story - even if you could change the switch, it would not work. Now, if you could crack the bcm so you could reprogram it.......
I wish it had auto up (like my 535 does), great thing when pulling out of the drivethrough - tap the switch and the window goes up leaving your hands free for....driving
Old May 18, 2009 | 11:11 PM
EmperorJJ1's Avatar
^^^^ x2 on the BCM thing. Even assuming you had full access and knowledge of how it worked it still would be quite a task
Old May 18, 2009 | 11:27 PM
Thanks for the info! Saves me a headache!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Tupp
Sep 30, 2015 08:18 PM
