Outside Temp. indicator "sticking"
Old Apr 22, 2018 | 02:10 PM
chuckabtjr's Avatar
Has anyone had their dash outside temp not work? The temp shows but does not change when I know it's warmer outside. Yesterday it read 37, then when I was driving later in the day it finally came up to the right temp.
Where is the sensor located?
Old Apr 22, 2018 | 04:56 PM
if I remember correctly take out the drivers side headlight and it will be there attached to the headlight bracket.
Old Apr 22, 2018 | 07:01 PM
chuckabtjr's Avatar
Thanks 07, would this be a connector issue or does the sensor go bad?
Old Apr 22, 2018 | 09:42 PM
could be sensor or maybe connection jiggling loose or connection needs to be cleaned out. i suspect nothing major or expensive
Theheavylp
Nov 12, 2010 02:53 PM
jcj08sta
Feb 17, 2008 10:26 AM
D4u2s0t
Jun 10, 2007 02:01 PM
M88ArRamadi
Apr 5, 2007 04:40 PM
bluedev1l
Jul 6, 2006 09:07 PM
