Projector Predicament
Old Dec 2, 2014 | 08:43 PM
brickloaf's Avatar
I have had this problem ever since I bought the projectors but never tried to fix it until recently but I am having zero luck even after what seemed like hours of tinkering. As pictured below my drivers side headlight beam is centered in the middle and has a crisp cutoff. However, my passenger side one is not centered and does not produce a very crisp cut off. I tried to readjust the bulb inside the projector by flipping it upside down and just moving it around but I couldn't get it anywhere closer than where it is now. Anyone have any idea what might cause this? Its pretty annoying because it doesn't really illuminate the passenger side when driving at night. They are Gen 1 projectors BTW.
Sorry for the not so great quality pics but you should get the point.
Driver side: the good side
Pass side: bad side
Old Dec 2, 2014 | 10:08 PM
andrewcarr1993's Avatar
It's the crappy projector in those headlights, sorry.
Old Dec 2, 2014 | 11:02 PM
First back up off the wall some. Then like andrew said it is most likely the projector and or the projector lens
Old Dec 3, 2014 | 04:08 AM
EmperorJJ1's Avatar
i can send you a gen 1 projector if you wanted to try it but idk if that would help or not and probably not worth the effort taking apart unless you were going to do so anyway
Old Dec 3, 2014 | 01:53 PM
brickloaf's Avatar
If it really is just because the projector is crappy that is unfortunate because I don't really like any of the other aftermarket headlights for cobalts.
Old Dec 3, 2014 | 02:03 PM
kcg795's Avatar
Crappy projectors. Get some HID projectors and retrofit your stock headlights. Also, go with 4,300k- 5,000k. Not 12,000k. Way too blue. A decent set of projectors with 4,300k- 5,000k bulbs will still give off a purple look at the edge of the cutoff that looks much better an exotic than chappy blue bulbs.
Old Dec 3, 2014 | 02:47 PM
EmperorJJ1's Avatar
retrofit the gen 1's... wont be cheap though. hit up bass waves and see if he wants to do another set
Old Dec 3, 2014 | 04:20 PM
Bass_Waves's Avatar
Gen 1 lights use some really bad projectors. Super crappy. Like I mean utter garbage. Your best bet is retrofits.
You can retrofit a nice projector in the Gen 1 . I have done them and it's time consuming. I can sure you there will be better results with a retrofitted stock or Gen 1 headlight.
As for coloring. I see way too much blue. What are you using? 8k or 10k?
Your best light output is around 4300 to 6k. My personal al favorite is 4300k. If you want true performance. Oem d2s bulbs and proper retros is the way to go.
Old Dec 3, 2014 | 05:10 PM
brickloaf's Avatar
I looked into retrofits but I am not trying to spend $500 on a pair of headlights since I would not be comfortable retrofitting it myself.
Old Dec 3, 2014 | 05:14 PM
Bass_Waves's Avatar
500 sounds like a pretty decent build. I start mines at lower prices and allow the buyer to buy them in 2 payments.
Old Dec 3, 2014 | 05:58 PM
kcg795's Avatar
I spent over $600 to build my retrofit. Totally worth it.
Old Dec 3, 2014 | 06:08 PM
EmperorJJ1's Avatar
i spent too much on mine but alot of it wasnt even the "retrofit"
Old Dec 3, 2014 | 06:39 PM
brickloaf's Avatar
I just genuinely like how the gen 1's look. In a perfect world I would retrofit the gen 1's and install ccfl or cob led halos, which I don't have the time or knowledge to do.
Old Dec 4, 2014 | 02:07 AM
EmperorJJ1's Avatar
Old Dec 4, 2014 | 06:02 AM
It's way to easy to drop money on good parts for retrofits.
Old Dec 4, 2014 | 09:51 PM
brickloaf's Avatar
Now those but black instead of blue, and red halos would be bad ass. And good projectors I guess....lol
Old Dec 12, 2014 | 10:25 AM
you get those mother effers on yet?
Old Dec 12, 2014 | 11:46 AM
Bass_Waves's Avatar
Last I remember he was having BCM issues with his lights
Old Dec 14, 2014 | 10:33 PM
EmperorJJ1's Avatar
ya turned out it wasnt the BCM and instead the fuse box under the hood had a short. anyway that was taken care of and i had planned to have them up and running today but i ran out of time/sun. i should have them up tomorrow
Old Dec 14, 2014 | 10:35 PM
Bass_Waves's Avatar
Nice. I made OP a set of retros too
Old Dec 14, 2014 | 10:36 PM
EmperorJJ1's Avatar
nice when was that?
Old Dec 14, 2014 | 11:00 PM
Bass_Waves's Avatar
Like a week ago. They shipping out tomorrow (monday). Pics are on my Facebook retro page. His look nice
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
juandirtymessican
Oct 27, 2012 10:41 PM
