Question about subwooder specs
I'm looking into buying a Skar Audio MA-8 and the specs say the Re at the voice coil is 4 ohms even though its rated at 2 ohms. My question is would it be safe to run the 2 ohm model in parallel on an amp thats only stable down to 2 ohms? Here are the specs on the MA-8 2ohm model
RMS Power : 400 Watts
Sensitivity : 82dB 1W/1m
Dual Ferrite Magnet Slugs (156mm x 25mm)
High Quality Foam Surround
Competition Grade Paper Cone
2" 4 Layer BASV Voice Coil
Custom Tooled Magnet Boot with Skar Audio Logo
Re : 4.00 Ohms
Fs : 44.1 Hz
Sd : 20.106 20.126
BL : 16.6 N/A
Qms : 4.39
Qes : 0.51
Qts : 0.46
SPL : 81.9 dB
Vas : 5.90 L
Cms : 102.75 uM/N
Mms : 126.54 g
Outer Diameter : 8.5" (216mm)
Mounting Depth : 5.7" (145mm)
Magnet Diameter : 6.3" (160mm)
Subwoofer Cut Out Diameter : 7.4" (188mm)
Subwoofer Displacement : 0.10 Ft^3
Sealed : 0.30-0.40 Ft^3
Ported : 0.50-0.75 Ft^3 @ 34 Hz
Re : 4.00 Ohms
Fs : 44.1 Hz
Sd : 20.106 20.126
BL : 16.6 N/A
Qms : 4.39
Qes : 0.51
Qts : 0.46
SPL : 81.9 dB
Vas : 5.90 L
Cms : 102.75 uM/N
Mms : 126.54 g
specs look like they are taken with the woofer in series (d2 in series= 4 ohms) and no its not safe to run the D2 model on an amp thats only stable down to 2 ohms. With a single dual coil 2 ohm woofer you can only run it at 1 ohm or 4 ohms.
If your amp is a mono block only stable to 2 ohms then you would want to get the dual 4 ohm woofer to run at 2 ohms.
