Rattle Elimination Tips and Tricks
Old Mar 4, 2010 | 01:14 AM
Nighthawk243's Avatar
Since the Cobalt is a known rattle trap, we need a thread of the various tips/tricks to eliminate rattles/sqeaks. This is very relevant to audio since it drives most of us bonkers when the car rattles on a sub hit.
A few I've found:
1) The covers for the LATCH system (The anchors for baby seats). These tend to have several contact points between the top of the cover and the sides. Cover this with anti rattle tape (or even electrical tape) and this should reduce or eliminate the rattling from those on Sub hits. If you don't plan on using them, you can just skip tape and superglue it closed permantly.
2) Door armrest mounts. The clips for the screws that hold your window switch bezel in on the arm rest is metal on metal and has a tendency to make a very high pitched rattle. Remove these clips, add some anti rattle or vinyl electrical tape to the clips (to eliminate metal on metal contact) and reinstall.
3) Door wiring clips (The "Christmas tree" style ties). The one directly above the speaker isn't exactly in there tight, and will vibrate. Again, tape works wonders.
4) When removing panels, you should use new panel clips, however, a single layer of vinyl tape (Or I've heard of gasket tack) will work if you must reuse the clips.
5) The screw covers for the door arm rest can be silenced by using extra felt beyond that pathetic strip GM puts on there stock.
If you have any more, definately post. No need to post about second skin or Dynamat...etc... that is just a known method already.
Old Mar 4, 2010 | 07:55 AM
Urban Rogue's Avatar
I currently have my entire Dash off and I am wedging 1/4" dence foam under the vent ducts etc. as they rattle around in there.
I also saped up all the seams where the vent pipe connect to stop air from escaping under the dash where I dont want it.
Old Mar 4, 2010 | 10:50 AM
Menace Kustoms's Avatar
Dome light lens. Drove me nuts forever until my friend figured out that's where it was coming from. I used a piece of scotch tape because it's clear, and you can't even tell it's there.
Old Mar 5, 2010 | 01:15 AM
EmperorJJ1's Avatar
yup.
Old Mar 5, 2010 | 09:14 PM
nouseforaname's Avatar
The dome drove me crazy too.. but what I did was fold up a piece of scotch tape until it fit snug into the gap between the back of the clear cover and the gray outter piece, and put it in there.
Old Mar 8, 2010 | 10:22 PM
notrice's Avatar
Peel the weatherstripping off the top of the doors and shove boxer shorts int your headliner. The plastic on the headliner rattles on the roof bad in my car.
Old Mar 8, 2010 | 11:24 PM
EmperorJJ1's Avatar
lol boxer shorts? if it works it works but yes i agree on that one too. i used second skin overkill but same basic concept
Old Feb 28, 2012 | 10:25 AM
deadthreadredemption
i'm gonna look into that headliner idea
Old Feb 28, 2012 | 02:34 PM
brickloaf's Avatar
can you peel the weatherstripping off then just push it back in? the roof is one of the few areas i have not sound deadened cause i have no idea how to get up there.
Old Feb 28, 2012 | 03:03 PM
EmperorJJ1's Avatar
yes but the weatherstripping doesnt hold the headliner up
Old Mar 3, 2012 | 02:35 PM
brickloaf's Avatar
i just want to stuff **** in there cause its right above my head that rattles...so i just peel it back, put stuff in there, and i can push it right back on?
everyone also consider the heat shield under the car...often this comes loose and causes a terrible rattle from underneath the car
Old Mar 3, 2012 | 03:13 PM
metalmedic's Avatar
My glove box... felt tabs worked awesome!!!!
Old Mar 3, 2012 | 09:10 PM
EmperorJJ1's Avatar
where the **** did u find them?
Old Mar 3, 2012 | 11:34 PM
metalmedic's Avatar
Walmart if ur talkin to me...
Old Mar 3, 2012 | 11:51 PM
LNFTX's Avatar
i just used old shirts in the headliner wires for the sunroof were just constantly vibrating against thr roof and in the rear deck stuffed them in the child restraints not sure what was rattlin back there but it fixed it
one more too the little access window on the top left side of my glove box buzzed for a week before i found that one and used some tape on it
Old Mar 4, 2012 | 12:34 AM
EmperorJJ1's Avatar
nice... ill check it out thanks. been looking for them for forever
Old Mar 16, 2012 | 11:06 AM
ginger's Avatar
anyone know what we can do about the heat shield rattling? OMG its so annoyin and loud!
Old Mar 16, 2012 | 11:11 AM
good tip i gotta try that, my roof rattles a lot somethimes
Old Mar 16, 2012 | 01:13 PM
Cobalt_Daddy's Avatar
i have a rattle in my console it's either near the shift linkage or behind the silver panel that shows the airbag lights below the radio. drives me nuts... i pull the cupholder out and stick my hand inside the console trying to find out where the rattle is coming from but can't find it.. cheap plastic.. sometimes i push on the faceplate and it goes away so maybe it's the trim around the radio..
Old Mar 16, 2012 | 10:46 PM
EmperorJJ1's Avatar
push the trim above the radio and see if that fixes it. i spent months trying to find that rattle in my car
Old Mar 16, 2012 | 11:03 PM
i'll give it a shot once it's out of storage next month... damn salt and snow
Old Mar 16, 2012 | 11:10 PM
nRRe's Avatar
what about...sunroof rattle? i lightly press on the glass upwards and it disappears. holy **** this drives me nuts.
Old Mar 16, 2012 | 11:23 PM
EmperorJJ1's Avatar
silicone it shut
Old Mar 17, 2012 | 12:57 AM
LNFTX's Avatar
Had this exact issue try cleaning the entire Weatherstrip or seal whatever you call it and the under side of the glass that touches it get all the dirt then lube the seal I just used original armorall lathered it on with a small brush and it's been good for a few months
Old Mar 17, 2012 | 01:18 AM
juice3's Avatar
sub'd.
jimbofug007
Oct 2, 2015 12:06 PM
TylerJHowell
Sep 21, 2015 06:47 PM
toledobalt
Sep 3, 2015 10:27 AM
