replacing stock sub
Old Jul 7, 2007 | 06:47 PM
krenfro88's Avatar
replacing stock sub
im thinking about replacing the stock sub with this http://www.onlinecarstereo.com/CarAu...roductID=18331 i could just take the old on out and bolt this right in correct? or is the box not big enough...and was also thinking about throwing in a small amp to get it a little more juice...does anyone forsee any big problems i might have occur during this?
Old Jul 7, 2007 | 08:23 PM
jschatte's Avatar
you will have to get a new amp to power the sub, the stock amp won't have enough juice. Also, if you buy a new amp and want to retain the stock deck, you have to get one of those preout maker dealies that hooks into your back speakers giving you a sub rca output. for the fitment, that sub is 6.1" deep and the stock box is 4". you have to make a 2" spacer and plug the unused hole in the back of the box. SO, this might discourage you, but i have done it:
Old Jul 8, 2007 | 05:11 AM
EmperorJJ1's Avatar
get a shallow sub... does alpine make one? i know fosgate and pioneer do
Old Jul 8, 2007 | 05:45 AM
Mnatvyc1223's Avatar
it's called a line out converter, and if you wire it right you can just splice it into the plug that is on top of the sub box, it's what i did.
Old Jul 8, 2007 | 07:56 AM
BRN169's Avatar
Technically it is called an impedance adapter and it converts/adapts the low-z (4Ω) car stereo amps output to a high-z (47,000Ω) line level input. They are not the best solution in terms of sound quality but if you want to retain the stock head it's about the only choice. Some amps (mostly lower end) have low-z inputs that do not require seperate impedance adapters...
bigdeertz
Nov 17, 2016 09:41 AM
Oct 21, 2015 11:57 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
