reverse lights as brake lights
Old Oct 13, 2011 | 10:21 PM
ssyeller's Avatar
what I would do instead of a bulb
Go buy a 3in led light and take the back bulb holder off and put the LED 3in in the opening and be all led for not much more than the bulb. Could be just brake or stop turn just like outside lights.
Old Oct 13, 2011 | 11:41 PM
SS SCHGD's Avatar
Mine work as the original poster wanted, LEDs added to the outer edge of the Back ups.
I'm looking to get my 3rd brake light added in soon too. (Brake and turn signal blinking)
Old Oct 14, 2011 | 12:35 AM
ssyeller's Avatar
One more option. Check this
I have a row of leds in the 3rd brake light attached to a sequencer that I made. It blinks in sequence either knight rider effect or anyother sequence I want depending on the wiring sequence.
Also When I took out the back up lights I put a strip of 10MM white leds behind the grid down by the exhaust area. I also ran a strip of Red leds in the same area which comes on as a 3rd light.
Old Oct 14, 2011 | 02:32 AM
dtowngreg's Avatar
well i just realized i have to get an inspection sticker next month so puttin a red bulb wont work. i have to have reverse lights
Old Oct 14, 2011 | 05:11 AM
1LowLS's Avatar
922 for the brake circuit and 194 for running light circuit.We dont have "inspection" in AZ.Just emission testing.you can always add a white bulb in each one as well for the revers circuit.it would be a cluster though.
Old Oct 14, 2011 | 12:10 PM
MastaShaKe_88's Avatar
why do all that? cant you jus tap into the appropriate wire for each one?
Old Oct 14, 2011 | 06:07 PM
dtowngreg's Avatar
got an estimate and they said ... 150-200.. yeah fuuuuck that
Old Oct 14, 2011 | 07:53 PM
1LowLS's Avatar
I used the Reverse light sockets and rewired them into the brake/turn circuit.All I did was leave the black(ground) wired as factory,Then cut the green wire on each reverse socket and wired it into the brake/turn on each side.Then I added a 194 socket in each reverse light and wired it to the running light circuit.Then just put red bulbs in each socket.I'm sure you can just use one bulb in each with a resistor or something,I dunno,it was easy for me to wire it this way.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
