Reverse Lights Wire
Old Jan 27, 2011 | 09:33 AM
snoftall's Avatar
Question Reverse Lights Wire
I am looking to tap into the wire which goes to the reverse lights.
Does anyone know where I can find it. It needs to be an easilyy accessible location and near the front part of the car (i.e. the driver and front passenger seating areas) or preferably in the roof/headliner. Thanks in advance.
Old Jan 27, 2011 | 10:30 AM
keiserX13's Avatar
What do you plan on doing?
Old Jan 27, 2011 | 10:39 AM
snoftall's Avatar
I need the signal from it to control something (turn something off) when the car is shifted into reverse, so it will not be drawing much current at all (so I don't need to worry about overloading the circuit).
Old Jan 27, 2011 | 01:53 PM
kikal8's Avatar
well i know that the wiring goes through the floor under the driver seat. where exactly isk
Old Jan 27, 2011 | 02:00 PM
Acey's Avatar
You can't splice into the hood fusebox to get it or you'll just get acc power... you might have to go the long route and just run a wire from the back.
Old Jan 27, 2011 | 02:18 PM
snoftall's Avatar
I was hoping to avoid this. I figured that there must be a wire somewhere between the ECM and the trunk, so I was hoping someone on here knew where it was and could quickly identify its location for me. If not, that is probably the only option I have!
Old Jan 27, 2011 | 02:20 PM
snoftall's Avatar
I'll see if I can pull the seat and take a look under the carpet to see if I can find any wires there. Thanks!
Anyone else know the exact location?
Old Jan 27, 2011 | 03:13 PM
KUNITZ's Avatar
If I recall, when I had to tap into this wire for my rear view camera, it was to the left of the driver seat on the floor, under the carpet. Its a greenish cable.
Old Jan 27, 2011 | 08:37 PM
kikal8's Avatar
ya i couldve sworn that i had to do something with that wiring. thats y i know that ha. but i forget what it was. but im almost positive thats where it is. let us know man.
Old Jan 27, 2011 | 08:45 PM
snoftall's Avatar
Awesome! I'll take a look there and let you guys know! I'm heading out of town tomorrow so I probably won't be able to look for it until next weekend. Thanks for the info on the wire color and location!!
Old Jan 28, 2011 | 03:12 AM
EmperorJJ1's Avatar
look up the alarm info for your yr balt and it might tell you an exact location for it. if i remember correctly mine was green white but i just tapped it at the trunk. lol i have it running to the radio but dont have a back up cam
Old Jan 28, 2011 | 03:29 PM
c4w18's Avatar
light green running from driver kickpanel into a harness to the rear. (+) trigger ofc.
and lol jj, ran it for the hell of it eh?
Old Jan 28, 2011 | 09:24 PM
EmperorJJ1's Avatar
hell ya i like my video to be interrupted when i put it in reverse... lol n ha i planned or want to put a rear cam its just low on my to do list
Old Jan 31, 2011 | 09:30 PM
snoftall's Avatar
Pulled my seats out and took a bunch of panels off the car tonight. You were both right. The main wiring harness runs right along the left side of the driver side front seat. I checked the wire going into the reverse lights and it is a light green color. Only problem I have now is I noticed there are a couple light green colored wires in the harness...the shades are just slightly off from one another and it is difficult to tell which one is the right shade of light green! I'll have to test one to figure it out. Thanks again for the help!!
Old Jan 31, 2011 | 09:53 PM
EmperorJJ1's Avatar
oh ya fyi we had a customer who was trying to tap the ebrake wire and out of the few he had he just guessed. turns out whatever he did was wrong and his door locks stopped working.
just be careful make sure to test it that its actually reverse. if you have a meter with long cords continuity test is always good
Old Feb 1, 2011 | 02:59 PM
c4w18's Avatar
yea, to be honest, easiest way to check is to probe that wire that you think is it, ground the negative probe, and see if you get a positive trigger on the meter, that is it goes from 0 v to 12 v when you put the car in reverse. just make sure your foot doesn't slip off the brake while you're juggling all this ****.
Old Apr 27, 2012 | 01:31 AM
fattywhat's Avatar
Well I have a kenwood dnx8120 double din and I'm trying to figure out where to run the reverse wire the purple one with out having it run all the way to the back
Old Apr 27, 2012 | 08:49 PM
c4w18's Avatar
driver running board....pop it off, wire is in that harness.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 04:49 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
