?'s with new head unit
so im plannin on getting a new head unit, etc. here is what i think i need, can anyone confirm
head unit: AVH-P4200DVD
GMOS-LAN-04
PAC SWI-PS (steering wheel controls)
GEXP920XM (xm)
CD-IU50V (iPod)
Metra 40-CR10 (antenna adapter)
i also want to know if im able to use my stock XM antenna on the roof.
any comments, concerns, things i should be looking for.
thanks
GMOS-LAN-04
GEXP920XM (xm)
CD-IU50V (iPod)
thanks
FYI since i got the same headunit. You dont need the ipod cable to play music off the ipod, you just need a usb cable like the one you use to sync the ipod on the computer. Only reason you would need it is if you want to play movies off your ipod, without the special cable it will only play sound and no video
thanks for the input. i am tryin to save money where possible, and this will help. i will not buy the iPod cable
also, im basing things off this post
https://www.cobaltss.net/forums/how-guide-43/how-wire-install-pioneer-avic-f900bt-f90bt-f700bt-2008-cobalt-ss-162483/
hopefully that will help others
i am planning on running my stock sub/amp for now until i get more money to get a new amp/sub combo. anyone think i'll have problems with that?
Last edited by kevinj4891; May 28, 2010 at 08:16 PM. Reason: Automerged Doublepost
im running the stock amp/sub also. Just make sure you run a power to the remote on the stock amp otherwise you will get no sound. I have no problems after 3 months. But after getting my amp/sub my stock sub is pretty much useless. Since i have the H/U set so the speakers play higher's and sub plays all the lows.
what harness are you talking about? i got rid on onstar quick, and i really can do without door chimes. the GMOS-lan-04 harness i was looking at was about $120. if i can reduce that, i'd be happy
thanks emporer. any tips/hints/ what not for me. im waiting about 3 more days to get my credit approved. i can get everything i need (as previously mentioned) for about $650. i have the cash now, just dont wanna spend that much at once, so i can finance it for 6 months with 0% interest.
again, i plan on running stock speakers / amp&sub in the beginning till i find a box that i like for the subs
might be changing my plans. work is getting a little slow and some people are losing hours (not me, thank you) don't know if i should go all out on head unit and the whole.
Emporer, your name keeps popping up the more i look at electronic threads...can i have yoour thoughts on what a good amp/sub would be for my Balt....
which way should the subs face (towards the side like stock, front, back)...
if i was to tap into stock h/u with am amp/sub, whats the best way and what parts...
any help would be great... leave your address so i can send you a check for your 2 cents.. :.)
hey not tryin to hijack but i was thinkin of gettin the AVH-P3200BT but on bestbuy.com they say it wont fit in my 06 ss/sc. is that a typo or does it not fit.. the head unit your talking about is pretty much the same but with a 7in screen
it will fit if you don't need the rca but if you do you can cut the plastic behind the radio and remove the factory radio suport bracket let me get some pics.
yes...what he ^^ said. you can cut the plastic bracket. i am doing the install next week, but here is another how to that shows you what to do with cutting
https://www.cobaltss.net/forums/showthread.php?t=162483
thanks a lot but i think im just too god awful with wiring. i just dont understand the whole 1st part of that thread. i dont think i can do it myself so i guess the kenwood HU would be my choice then.
edit: im getting help for the install need parts now
i've never done a headunit install, so i have a friend at work helping with the wiring, and of course, Emporer.... i am fairly competent with wiring, but only after i have had help once before. once i am taught how to do something, i always remember and can do it by myself.
as for the wiring harness, it basically comes down to matching the colors. as i always do...RESEARCH RESEARCH RESEARCH. find out what others have done, find out what problems to expect, etc. then its taking your time, read what color goes where, and matching them up. it's really not that difficult.
if it makes you guys feel any better one of the main reasons i recommend metra as a whole is in each component it has instructions on what to do. depending on the car i for the most part color match the cheap harnesses like everyone else but on any of the module or interface harnesses i sit my happy ass down and read the instructions to a T.... may not be necessary since ive done so many but its worth making sure its right.
as long as you buy metra or crutchfield its fairly easy to do with or without prior experience. they even list what tools you need
Agreed
The instructions on there dash kits have been a life saver on some of the installs I've done for friends.
My buddies Cavalier is one that comes to mind, since you have to take half the dash out to get at the bolts that hold the radio in but they walk you through it step by step.
OP- after you cut the plastic from behind the HU, there is a metal support bar that holds up the stock HU right behind the plastic, its held in with 4, 9/32 (7mm) nuts. its tricky to get at 2 of them but worth removing depending on the HU your putting in. Pinching wires up against metal may cause problems, pinching signal wires (RCA's) will cause problems, like high pitched interference.
thanks for the heads up. now i just have to find a local shop to buy power/ground wire and RCA's for my amp
all have local is best buy and al&eds (be prepared to get ripped off)
agentirons
Oct 16, 2015 02:11 AM
Sep 28, 2015 12:51 PM
