Sound Quality Systems!!! (pics)
Old Oct 25, 2007 | 12:53 PM
  #201
06CobaltssOrange's Avatar
lol wow i wish you guys could see my system lmao ugly as hell but she hits i have 1 12 inch mtx thunder 6000 sub and 1 12inch in a pioneer box feeding from a lightning audio 900 watt 4 channel amp and a phoenix gold amp also my stock 10 is still in it to. It hits but its ugly as sin but its just for now when xmas comes im getting 2 12inch kenwood carbon series 12s and a ported box and the perfect complemented amp. but for now ugly it is lmao.
Old Oct 25, 2007 | 01:06 PM
  #202
BradSi's Avatar
Ha man I think were tied. I have one of my MTX 7500's in a black MDF box, then my MTX 421d amp. Sub is sitting in the trunk, all my wires are hid under the trunk carpet and my amp is held in the trunk floor on the right side of the sub. Now for the kicker, when I got my car, it had no trunk floor cover, no spare tire and no jack. So I made a floor outta thin board and it's been in there so long that its bowed. Gotta actually finish my trunk sometime...
Old Oct 26, 2007 | 09:41 PM
  #203
fortmaccobalt's Avatar
haha ^^ those sound like some ghetto set ups but do they at least sound decent?
Old Oct 30, 2007 | 05:57 AM
  #204
EmperorJJ1's Avatar
Old Oct 30, 2007 | 08:44 AM
  #205
sick06cobalt's Avatar
urgh i hate retarded people
Old Oct 31, 2007 | 05:00 PM
  #206
Kwin's Avatar
My Sq is the Eq Knob... i think the stock system is pretty good and im really into music
anyone agree?
Old Oct 31, 2007 | 06:31 PM
  #207
Bumpin Balt's Avatar
The stock system is pretty good for a factory stereo. But it just doesn't cut it if your used to high powered after-market stereos.
Don't be so hard on yourself!
Last edited by Bumpin Balt; Oct 31, 2007 at 06:31 PM. Reason: Automerged Doublepost
Old Oct 31, 2007 | 06:32 PM
  #208
Area47's Avatar
Rent me! per hour
you'd be amazed at what a headunit can do
Old Nov 1, 2007 | 03:14 AM
  #209
SS SCHGD's Avatar
were talking sound quality in here, right?
Old Nov 1, 2007 | 04:23 AM
  #210
EmperorJJ1's Avatar
lol ya sorta went a lil off topic here.... hey ss supercharged have u ever herd of or seen a sealed box in a ported box? Im seriously thinking about it
Old Nov 1, 2007 | 01:27 PM
  #211
a sealed box inside a ported box. never thought of that. sounds interesting
Old Nov 1, 2007 | 06:03 PM
  #212
SS SCHGD's Avatar
You asking me? (I know there is someone on here that is "ss supercharged") I've heard of the sealed in a ported, most of the time it's called Bandpass, unless there is a different design your thinking of? Bandpass is a limited output setup though, very narrow range of great output.
Old Nov 2, 2007 | 02:53 AM
  #213
EmperorJJ1's Avatar
no not a bandpass an actual box that can be converted from sealed to ported. See im going to have a box thats ported thru the rear deck. and because of the extreme spl even the XXX's will make (but im having a comp only setup as well) i like to brace the box heavily. So my idea is find out how much space is required for a sealed box and where that is make a ring brace. But have a removable plexi or mdf piece attached. So with the plexi its a sealed box without its a ported (mind u ports are behind this area)
Only problems im seeing is im going to have to have 2 removable parts of the box (the first the change from sealed to ported and the second to remove the first piece. And im concerned with being able to get the first piece thru the second
Old Nov 2, 2007 | 06:39 AM
  #214
Kwin's Avatar
i dont like the look of the head unit either i like the stock look inside
Old Nov 2, 2007 | 06:30 PM
  #215
SS SCHGD's Avatar
So you looking to build a Ported Box (sized and ported to the recomended sizes) with the ports on the back of the box and a cut in the box that you can put a blocker in and cut the size of the box down (to recomended Sealed box size)
Seems reasonable, other then you'll never get a removable piece to seal air tight with that kindof force....But I see what your going for.
I'll add a picture in a min of what I think your going for....
Old Nov 3, 2007 | 03:23 AM
  #216
EmperorJJ1's Avatar
sorta like that but not really
heres an example of a ring brace
http://rides.webshots.com/photo/1233...38953658NIdScO
its a lil fancy with the circle in the middle of it for more support but u get the idea.
So replace that with a window or mdf piece like the outer chamber of a bandpass box and your got a "convertable" box
Old Nov 3, 2007 | 05:08 PM
  #217
SS SCHGD's Avatar
I haven't seen or heard anything similar to the setup your talking about, but it's a interesting design. let me know how it goes.
Old Nov 3, 2007 | 06:39 PM
  #218
EmperorJJ1's Avatar
ya i havent herd of anything like it either but if i can get it right that would be awsome... just thought of another problem thou wiring
Old Nov 11, 2007 | 05:33 AM
  #219
SS SCHGD's Avatar
why would the wiring be a problem? You can put the wire through on the sealed side and when you pull the middle piece it won't be in the way.
Old Nov 11, 2007 | 06:30 AM
  #220
EmperorJJ1's Avatar
huh? the terminals are going to have to be on the back piece or possibly the side. either way its wiring thru the sealed to ported piece that scares me
oh ya did u see the bottom of my sig... im excited
Last edited by EmperorJJ1; Nov 11, 2007 at 06:30 AM. Reason: Automerged Doublepost
Old Nov 12, 2007 | 05:43 PM
  #221
SS SCHGD's Avatar
I mean why do the terminals have to be on the back, or somewhere that you wire thru the moveable piece?you could always double layer the wood and run a piece of Copper inbetween the pieces from the back to the front chamber.
Old Nov 14, 2007 | 04:46 AM
  #222
EmperorJJ1's Avatar
well the sub box is going to be forward firing and the amp/batteries are going to be in the back
Old Dec 17, 2007 | 04:53 PM
  #223
jimmyfoxx's Avatar
Old Dec 18, 2007 | 08:15 PM
  #224
widebody_balt_ss's Avatar
thats alot of air space for those typhons isint it?
Old Dec 18, 2007 | 08:26 PM
  #225
EmperorJJ1's Avatar
not nessicarily... i doubt all of it is box and it doesnt look like it stickes out too far
