Stealership an there keyfobs
u can program the remote yourself. i copy and paste this from nother site.
I pulled the interior fuse cover from the passenger seat.
I located and pulled the 10A fuse for the Radio (labeled RDO).
I turned the car to the on position to verify the radio was disabled.
I turned the car back off and removed the keys.
I waited 30 seconds (I'm a Network Engineer, we always wait thirty seconds after unplugging something).
I put the fuse back into the correct spot.
I then held down the lock and unlock key on the keyfob at the same time till the locks on the doors activated.
I then tested the keyfob and made sure it was locking and unlocking the doors and activating the security system.
This process did reset my security settings on her car so I had to go through the reset process (holding in the information and reset key at the same time then following the prompts).
The keyfob now works, and I didn't have to pay some ******* dealer $50 for 15 seconds.
After looking at the keyless fix I thought I'd try and invent one myself. I ended up putting a piece of aluminum foil in each of the indents of the lock and unlock buttons in the rubber part. After I put it back together it worked like a charm. Cost - $0 Time - 15 seconds
Alright so i took the Balt to the Stealership the other week because my key fob had been going in and out (not working) I've had my car since Jan. so i figured i would still have some warranty (i pay extra for it monthly), which is a electrical warranty but the lady tells me it will be $160 to replace it. So i was wondering if i could order the key fob off of ebay for around $10-$20 an then get it programmed by the stealership an maybe what price that would cost me if anyone would know.
my 05 redline keyfob stopped working after I took it in for the security lock light that kept coming on.
any idea which method would work best than droppin about 60 bux at the "stealership" ( thats pretty witty never heard it before!)
Blackbirdws6zzz
Mar 27, 2007 07:56 PM
