Steering wheel control issue PAC Audio SWI-CP2
Old May 17, 2019 | 09:32 PM
adude007's Avatar
Hi all
Ive been trying to get the swi-cp2 steering wheel controls unit functioning. My #1 problem right now is that the unit will not even power on no matter how I hook it up. Has anyone else used one of these successfully? If so, do you remember what you did to get it working?
Thanks!
Old May 20, 2019 | 09:07 PM
EmperorJJ1's Avatar
i have. they are a pain and super finicky. did you go to the website and look at vehicle specific instructions?
Old May 22, 2019 | 01:05 PM
adude007's Avatar
Yes I did. I even sent images to PAC to ask their opinion. Tried different powering it from different circuits and direct to the battery.
I wound up getting the Metra ASWC-1 last night and it works but the button mapping it came up with is wrong but the thing functions well enough for now. I’ll just memorize the new buttons.
Old May 23, 2019 | 01:44 AM
EmperorJJ1's Avatar
ah ok couldn't you just remap the buttons. probably over it since you've had so much hassle thus far though
Old May 24, 2019 | 04:54 PM
adude007's Avatar
The only issue with mapping is that you cannot change the volume up button through the manual process on the ASWC and because it is telling the head unit both are volume up I cannot manually map through that interface either.
Old May 24, 2019 | 05:07 PM
Sharkey's Avatar
i have the same problem with mine, now with both the 4 spoke and 3 spoke wheels. im able to get through the mapping process but in the end both volume up and volume down buttons are seen as volume up.
eventually im gonna try a pac module. the first head unit i had in my cobalt didnt have a steering wheel input so i used an inferred steering wheel control from PAC and it worked flawless.
Old May 24, 2019 | 10:52 PM
adude007's Avatar
I am not alone! I have the volume down via source. So, I at least can control what I want via the wheel.
Old May 24, 2019 | 11:17 PM
Sharkey's Avatar
nope, your not alone. and i seem to remember reading about others with the same issue.
i did try programming volume down to another button and it worked then. i think what the problem is is the volume up and down buttons have a resistance value too close to each other, and the axxes module cant pick up a difference. i remember reading something at some point saying to try putting a resistor inline between the module and the input wire to correct it, but it didnt work for me.
Old May 26, 2019 | 09:02 AM
adude007's Avatar
Looking at the schematic vol up is noted as 1.27k ohms and down is 294ohms. Source, which is my vol down, is 348 ohms.
Sharkey
Jan 3, 2014 08:32 PM
chitala383
Jan 31, 2010 10:26 PM
1995droptopz
Dec 2, 2008 01:18 PM
wski440
Sep 21, 2007 11:32 PM
redline85
Sep 18, 2006 08:57 PM
