Stereo Help needed!
Old Apr 21, 2008 | 09:24 PM
Stubri51's Avatar
Stereo Help needed!
So i had a little incident with my HU and im looking at getting a new one. Crutchfield says that out car has a euro din set up. Will a double din such as http://audiovideodimension.com/index...s&stat=reviews fit in the car. If so would i need to modify anything?
Old Apr 21, 2008 | 09:26 PM
KillerBee's Avatar
Yes double din do fit all you need is teh double din plastic dash kit that holds the radio in
1 question you do have a cobalt right
Old Apr 21, 2008 | 09:28 PM
Stubri51's Avatar
where is the best place to get one
Old Apr 21, 2008 | 09:30 PM
KillerBee's Avatar
bought mine from here
http://www.sonicelectronix.com/item_...l+GM-K352.html
Old Apr 21, 2008 | 09:32 PM
Stubri51's Avatar
Hey thanks. I looked up the specs on it and it will be tight but it will fit depth wise i think there was a 1/4in extra. But crutchfield says it wont fit
Old Apr 21, 2008 | 09:34 PM
KillerBee's Avatar
i am not sure i know our cars can hold a double din i dont know about the one you want but its a double din it should fit. I know so have to be modified to fit like the back part something with it needs to be cut or something mine fit fine though then again i bought a power accoustic double din
Old Apr 22, 2008 | 12:27 AM
Spun's Avatar
Most of us had to cut some of the plastic molding the at sits behind the HU, also remove the metal bracket that supports the stock HU.
Carefull not to cut your heater vents
The Metra 95-3302 will also work
Old Apr 22, 2008 | 02:17 AM
EmperorJJ1's Avatar
right all explained in the FAQ up top...
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
