Stereo Help needed!
Stereo Help needed!
So i had a little incident with my HU and im looking at getting a new one. Crutchfield says that out car has a euro din set up. Will a double din such as http://audiovideodimension.com/index...s&stat=reviews fit in the car. If so would i need to modify anything?
i am not sure i know our cars can hold a double din i dont know about the one you want but its a double din it should fit. I know so have to be modified to fit like the back part something with it needs to be cut or something mine fit fine though then again i bought a power accoustic double din
Most of us had to cut some of the plastic molding the at sits behind the HU, also remove the metal bracket that supports the stock HU.
Carefull not to cut your heater vents
The Metra 95-3302 will also work
Iceberg
Sep 29, 2015 12:33 PM
