ugh! help please!
Old Apr 18, 2009 | 02:24 PM
timmhimself's Avatar
ugh! help please!
sorry to be a pain again...
i got everything hooked up with my amp and subs but i can't get my remote wire to work, i've tested and spliced it into 2 of the wires behind the stereo and they've both cut in and out. one worked at low volume but would cut out past about 1/4 of the way up.
it can't be the amp because if i bridge the remote to the positive it works just fine...
do i possibly have a bad remote wire?
where did you guys wire yours to?
Old Apr 18, 2009 | 02:25 PM
BLAZIN07SS's Avatar
I'm too JDM for you
passenger side fuse box. get an add-a-circuit and put it to your windshield wiper fuse
Old Apr 18, 2009 | 02:33 PM
alright thanks!
Old Apr 18, 2009 | 02:36 PM
Maetrix's Avatar
I have a question on that, Which side of the WW fuse is the fused (output) side of the fuse?
Old Apr 18, 2009 | 02:38 PM
BLAZIN07SS's Avatar
I'm too JDM for you
save yourself a headache and putting more stress on the electrical. get one on these mini add-a-circuit http://www.sportsimportsusa.com/miatmfua.html
you can get them at your local auto parts store!
Old Apr 18, 2009 | 02:44 PM
Maetrix's Avatar
I'm already heavily invested in these, LOL
Old Apr 18, 2009 | 02:46 PM
is there a certain size i should be looking for?
Old Apr 18, 2009 | 02:47 PM
BLAZIN07SS's Avatar
I'm too JDM for you
mini ATM fuse add-a-circuit. make sure they are the mini ATM fuses.
Old Apr 18, 2009 | 06:52 PM
alright cool. thanks.
problem...when i plug it into the wiper fuse i get no power what so ever and my wipers no longer work. i tried it on other fuses and i get power the only problem is they're all constants...
Last edited by timmhimself; Apr 18, 2009 at 06:52 PM. Reason: Automerged Doublepost
Old Apr 18, 2009 | 07:14 PM
SS SCHGD's Avatar
it almost sounds like the Positive and Remote wires are connected backwards. Like he's trying to give it power from the Remote output of the Headunit. Double check your connections at the Amp, and What head unit do you have? (what wires are you trying to use off it?)
Old Apr 19, 2009 | 01:51 AM
EmperorJJ1's Avatar
if hes hooking up the remote to random wires in the stock radio harness probably not. but i do see where ur going with that ss.... its hard to fully understand wtf hes talking about.
Be warned there is no acc or remote in the stock harness. you might be taping ur GM LAN wire and one mistake and your computer is fried... tread softly my friend
Old Apr 19, 2009 | 02:29 AM
SS SCHGD's Avatar
there is definately something goofy going on there...I would have someone else (that knows what there doing) check out the harness and connections.
Old Apr 20, 2009 | 10:49 AM
i got the bone stock head unit (single cd, am/fm stereo), i'm not tapping off of that. i tried the ATM add a fuse in the wiper fuse and its not working. i decided to try the AMP fuse and it did work but its a constant circuit so i can't use that.
i have the remote wire hooked up to the RMT port on the amp and the positive to the 12v...
Old Apr 20, 2009 | 12:45 PM
EmperorJJ1's Avatar
try the sunroof fuse
Old Apr 20, 2009 | 12:48 PM
hedtrnr's Avatar
thats what i have mine running off of. took a lil time but mines running off the sunroof fuse
Old Apr 20, 2009 | 03:41 PM
i don't have a sunroof...
Old Apr 20, 2009 | 03:50 PM
M&CBlackSS's Avatar
my remote wire is hooked up to the power windows and works fine try that
Old Apr 20, 2009 | 03:53 PM
Maetrix's Avatar
But the fuse location should still have power, right??
I mean, this is GM, they don't have multiple harnesses for different configurations.
Old Apr 20, 2009 | 04:11 PM
that what i figure but wasn't sure, if it weren't nasty out i would have already been out trying it.
i'll give it a shot when it stops raining.
Old Apr 20, 2009 | 07:10 PM
SS SCHGD's Avatar
my 05 had a sunroof fuse but no sunroof....and it worked just fine. (although I think I used a relay in that car cause I ran some other stuff off it. But the Sunroof fuse has enough juice to turn on my amp and run the sunroof in the SS. (and the amp is OLD!)
Old Apr 20, 2009 | 07:47 PM
EmperorJJ1's Avatar
neither do i but it still worked for me
Spectral
North Pacific
Jun 4, 2008 02:11 AM
Coblt ss super
Apr 26, 2007 09:58 PM
