Weird Security System
Old Nov 3, 2012 | 08:16 PM
Dunedain05's Avatar
Ok so I just bought a 06 cobalt ss and they did not have the manual. When I lock the doors via the pwr lock button and then try to unlock the doors via the key (because the unlock and lock doesnt work on the key pad) the security system goes off...but not every time. Though if I just lock the doors manually it wont. Is there a weird way to do this that I dont know about or is something shorted or something.
Old Nov 3, 2012 | 08:20 PM
VapeWI's Avatar
Mine used to go off when I locked it with the keyless and unlocked with the key(because my keyless broke). But when I lock with the door button it doesn't go off if I unlock with the key. Sounds like something is up with yours, I'd get it checked out.
Old Nov 3, 2012 | 08:52 PM
Dunedain05's Avatar
ugh electronic work is so expensive...the big question is if it was factory or if it was wrigged up with an after market set up
Old Nov 3, 2012 | 09:00 PM
Whining-devil's Avatar
security system goes off when you press the lock button, if you lock it manually it does not go off.
Old Nov 3, 2012 | 11:18 PM
Dunedain05's Avatar
yea I think Im just gonna have to do it manually and bypass the problem. Dont feel like tearing into it.
Old Nov 4, 2012 | 02:48 AM
EmperorJJ1's Avatar
do u hit the lock button once or twice? if u engage the alarm the expected behavior is for the alarm to go off when not using the key fob. Hitting the lock button twice engages the alarm. hitting it once isnt supposed to engage the alarm its just supposed to lock the car BUT sometimes it engages anyway.
There is nothing to tear into this is how the car comes stock
Old Nov 4, 2012 | 09:27 AM
Dunedain05's Avatar
I think I do have to hit it twice but for some reason Im thinkin I had to for some reason. What is buggin me is that it doesnt always do it!
Old Nov 4, 2012 | 09:31 AM
Squints's Avatar
when you hit it the first it chimes and shows the security light the second time you hit it it engages the alarm then locks the door. Mine does this every day ive gotten to the point of just doing it manually until i get the new fobs for it and get them programmed
Old Nov 4, 2012 | 11:08 AM
Dunedain05's Avatar
Mine doesnt chime but yea it doesnt lock till the second time you hit....sucks doesnt it. Im just gonna do it manually.
Old Nov 4, 2012 | 11:13 AM
bluebalt07's Avatar
It is supposed to set the alarm off if locked with the with the electronic locks and unlocked with the key. Same if you were to say have your windows down and by habit lock the doors and then reach through the window to unlock it. Just the way it is set up. I'd just get new fob if I were you. Or try to repair yours because I think there's a how to on here for it
Old Nov 4, 2012 | 11:17 AM
redssna's Avatar
Your car is fine. Buy a new key fob, have it programmed, end of problems.
Old Nov 4, 2012 | 12:10 PM
Squints's Avatar
There's a guy on here that selling them pretty cheap
Old Nov 4, 2012 | 12:46 PM
Dunedain05's Avatar
What exactly is involved in getting a FOB? Is it a new program for the system? Does it involve installing a whole new system? How much we talkin? Never delt with this before.
Old Nov 4, 2012 | 12:49 PM
bluebalt07's Avatar
Pretty sure the dealership just has to reprogram the fob itself
Old Nov 4, 2012 | 12:57 PM
Gelladuga69's Avatar
$50 or so for 10 seconds of work.
Old Nov 4, 2012 | 01:03 PM
bluebalt07's Avatar
Typical gm rip off
Old Nov 4, 2012 | 01:43 PM
Dunedain05's Avatar
So all they do is reprogram it?
Old Nov 4, 2012 | 01:45 PM
bluebalt07's Avatar
Yep just reprogram it to your car
Old Nov 4, 2012 | 06:18 PM
blueLNFftw's Avatar
They can reprogram the BCM to your FOB. However, it is an all at once shot. So if you want two remotes then buy two and do it together. Its like $70 bucks from them to do it. And before you ask, no, only a GM dealership can do it.
Old Nov 4, 2012 | 06:36 PM
Anybody with a Tech2 or similar.
I went to a lock smith with a Tech2 and another device that could do it.
He said he liked the other device better because it didn't require using an VIN numbers, which is what he used on my car.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
