What do you have for a stereo system
i beg to differ...unless u put the T1 in the right sized box tuned to w/e kind of music u listen to it sounds great and it will get VERY loud for what it is...ive suprized MANY people with my setup
My setup consist's of Alpine x305s H/U, JL C5-650 Components, Alpine PDX 4.100, Hifonics Brutus 1600 watt, 2 10" RF T1 Dual 4's (wired at 1 ohm) in a 3cu.ft. box with the port tuned to 38hz
i plan on getting 2 DD 9510z's, box size is undetermind yet with the port tuned to 35hz with 2 AQ 3500.1D's (4k @ 1ohm each) strapped and wire the subs down to 1 ohm, 2-3 XS Power d3100's, and possibly a 250-300amp MECHMAN H.O. alt with lots of 0 guage
EDIT: o and forgot to mention lots and LOTS of damplifier pro
your T1 probably needs a better box or more power.
I'm running a Old Sony ES 5 channel amp, with Diamond Audio D6 components in back and Infinity Kappa Perfects in front. Has a 10" Rockford Shallow P3 in the stock box, and a Pioneer Avic F900BT head unit.
Probably going to a pair of JBL amps, a MS-A1004 and a MS-A5001, and then a JBL 660GTi fronts (or C608GTi MKII) and a JBL W12GTi sub in a sealed box.
Pioneer Avic z110bt; Alpine PDX-5; Focal 165A-1 front, Focal 690CA rear, Focal 25A-1 sub
__________________________________________________
Black 2010 SS/TC G85 |Debadged | GMS1 | Hahn 3 DP and Catback | AEM intake | GM racing pedals | OZ Ultraleggera rims |DEPO 4th gen projectors w/ 6K HIDs | smoked LED tails | 20% 3M tint |Pioneer Avic Z110bt head unit, Alpine PDX-5 amp, Focal speakers all around
http://www.cardomain.com/ride/3835837
woah i missed that one. um ya ud need to put alot of money into the electrical to not fry those amps and those subs might be be able to handle the power but mmm idk
that would be cool but im gonna lean towards brick on this one. it wont last long if its exactly how u put it
yo brick....for the setup you're running did you tinker with your alternator at all? j/w because i'm getting a new setup quite similar to yours....same mono and a new fully loaded fi btl....input from empjj would be nice too, although i'm never going to have the same god tier dual alt setup as him, i need some advice on alt. amperage output and whether or not i need to upgrade. going dual kinetiks and doing the big 3 so i don't know if its necessary.
Mine is 6 1/2 3 way Kickers in front doors, 3way Sony 6x9s in rear deck.
All running off factory HU.
10 Inch Memphis sub in a Factory sub box running off 400 watt Rockford Amp.
running amps a .5 draws way more current then 1 ohm for not that much more power. the zs will only take that power if its 100% clean and even then its pushing it. you would need my electrical system + some to get 8k clean watts running at 1 ohm per amp. for 9k at .5 per amp isnt going to work for very long. the subs or amp will take a hit quick and they aren't too cheap to recone
yea i was thinking about that at work today i dont really feel like reconing the Z's after hammering on them time after time demo after demo so i may jus stick with 1 amp for now until i can figure something out later on...who knows i may get a SAZ-4500d...i donno yet im still deciding on the amp and the electrical to back it up...maybe sometime by december or january ill start on this project...when my funds allow me to
