what to use 4 for High level inputs
Old Jul 12, 2008 | 12:42 PM
jimmyfoxx's Avatar
what wires should i splice to use the high level inputs on my amp? im thinking the wires going to the stock sub.=?
Old Jul 12, 2008 | 02:17 PM
jacobmprater's Avatar
you need a line out converter. i have one for sale if you want on ill seel ya my old one for $15+shipping. its a stinger. only about 10 hours on it. i spliced into both rear deck speakers.
Old Jul 12, 2008 | 06:43 PM
jimmyfoxx's Avatar
i got one in my amp already i was just wondering if i should slipce the 6x9's or the stock sub. i just used the stock sub
Old Jul 12, 2008 | 10:04 PM
EmperorJJ1's Avatar
for high level inputs splice the stock sub wires. easier on your part and you should really disconnect the stock sub anyway (if you cut the wires completely then just plug the connector in the stock sub and be happy. If you t-tap then just disconnect)
not for high level inputs
Last edited by EmperorJJ1; Jul 12, 2008 at 10:04 PM. Reason: Automerged Doublepost
Old Jul 12, 2008 | 10:21 PM
Switt23's Avatar
Wouldn't it depend on what the amp is going to power? If it's for the fronts, i would splice the fronts from behind the stock head unit... if it's a sub or rear speakers, use the sub.
Only reason i say that is because then you can't fade it front to back if you splice the rear for front speakers.
Old Jul 12, 2008 | 11:26 PM
EmperorJJ1's Avatar
true but since he specifically mentioned splicing the sub wires i assumed he was talking about the sub. Of course for fronts you splice the fronts and rears you splice the rears
Old Jul 13, 2008 | 12:08 AM
Switt23's Avatar
Was just making sure he was... not just trying to take the easiest signal wire to get to.
Old Jul 13, 2008 | 12:22 PM
jimmyfoxx's Avatar
yeah the using it for 2 12's subs. i spliced it the stock sub wires sounds good
no_ss
Oct 18, 2015 11:58 PM
Builttss
Oct 4, 2015 10:21 AM
jimbofug007
Oct 2, 2015 12:06 PM
Slick_Nick
Sep 28, 2015 09:15 PM
roth
Sep 26, 2015 12:16 PM
