Will not Start after i replace a headlight bulb
Old Jan 28, 2012 | 12:29 PM
kingcobalt08's Avatar
Well the question says it all, i replaced the passanger side bulb after i replaced it i made sure for it to work and it worked fine, (i had the key in the acc the whole time) i then tried to turn it on but it wouldnt do nothing. Any suggestions, on what it might be?
Also the passanger turn signal will stay on.
Old Jan 28, 2012 | 12:37 PM
Validater's Avatar
Do you hear a ticking coming from the starter when you try to start it?
Old Jan 28, 2012 | 12:50 PM
no i dont hear nothing is there any relays, that could go bad, i visually inspected the fueses they seemed fine
Old Jan 28, 2012 | 12:51 PM
mkulrey13's Avatar
jump start your car..
Old Jan 28, 2012 | 12:53 PM
Validater's Avatar
^ this, your battery probably died with it in acc.
Old Jan 28, 2012 | 12:54 PM
Validater's Avatar
If that doesn't work, all I can say is try disconnecting the battery for a few minutes, just ground is all you need to disconnect.
Old Jan 28, 2012 | 12:59 PM
srry forgot to mention that i tried jump starting it and nothing, i disconnected the battery for no more than 30 seconds to see if it would reset and nothing, i dont know what else to check. other suggestions?
Old Jan 28, 2012 | 01:03 PM
Validater's Avatar
Leave it off for 5 mins
Old Jan 28, 2012 | 01:16 PM
allright ill give it a try and see what happens, thx
Old Jan 28, 2012 | 01:34 PM
allright i disconnected the posotive from the battery and still i got nothing
Old Jan 28, 2012 | 01:40 PM
SunburstSS's Avatar
unplug the whole passenger headlight harness and try turning it on, the bulb that u just installed might be causing a short, then try jump starting if necessary, then you can pinpoint the problem from there...
Old Jan 28, 2012 | 02:23 PM
thx, i unplugged the passanger headlight then connected it to the battery charger and it started right up.
Appreciate all the help
Old Jan 28, 2012 | 03:58 PM
SunburstSS's Avatar
np man thats what here for ! help each other out ! Now you know u have something wrong in that wiring or one of the bulbs is shorting out just pin point the issue now
Old Jan 28, 2012 | 07:07 PM
Validater's Avatar
Thanks SunburstSS, I was out of ideas, strange how that happened, but good to know.
Meadowvalien
Aug 17, 2017 06:32 PM
chefhhr
Oct 26, 2015 10:36 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
How to Guide
57
Oct 15, 2015 11:56 AM
royce777
Sep 28, 2015 07:11 AM
