Wiring help please....
so i did the how to glowing trim and got everything wired up correctly but i cant seem to find the wire that runs the dash lights at night.
also i am having trouble finding a place to put the ground wire. can someone point out those places please. thank you!
put ground on anything metal that attches to the frame of the car. as for the dash lights, no idea. google wiring schematics and u mght be able to find something. unless someone has access to gm tech articles or someone has the schematics from elsewhere.
always on is any ACC wire, there are lots down there, or you can use a fuse tap which will be easier.
sunroof fuse will give you RAP power as well.
if you want it on ONLY at night, you'll need to tap a wire that powers on with the ambient light sensor.
DONT use that 2amp fuse on the top row. its ignition but it'll blow very easily and you'll be in trouble.
Use the fuse position 4th row down, 2nd in....i think its #16....and yes I realize you dont have a fuse in that slot currently
this ones a 15amp slot and gives you RAP power (works with IGN even when the car is off until the doors are opened)
