Wiring help please....
Old Jun 24, 2012 | 01:08 PM
itz_joker_xl's Avatar
so i did the how to glowing trim and got everything wired up correctly but i cant seem to find the wire that runs the dash lights at night. also i am having trouble finding a place to put the ground wire. can someone point out those places please. thank you!
Old Jun 24, 2012 | 01:13 PM
K-Train04RL's Avatar
put ground on anything metal that attches to the frame of the car. as for the dash lights, no idea. google wiring schematics and u mght be able to find something. unless someone has access to gm tech articles or someone has the schematics from elsewhere.
Old Jun 24, 2012 | 01:19 PM
acoutu's Avatar
if i remember right its a grey wire, but i tapped into the map lights just above the roof liner, not at the bcm. its easy to find up there with a test light, only 3 wires.
Old Jun 24, 2012 | 01:37 PM
i just want these lights to come on when i turn the car on. there has to be a wire down there that does that
Old Jun 24, 2012 | 09:19 PM
acoutu's Avatar
always on is any ACC wire, there are lots down there, or you can use a fuse tap which will be easier.
sunroof fuse will give you RAP power as well.
if you want it on ONLY at night, you'll need to tap a wire that powers on with the ambient light sensor.
Old Jun 24, 2012 | 09:28 PM
Ceej's Avatar
Just hook it up to a fuse and use a switch.
Old Jun 24, 2012 | 09:41 PM
cobaltss#01's Avatar
The third fuse on the top from the right Will work with the key .
Old Jun 24, 2012 | 09:50 PM
Sorry from the left side not right.
Old Jun 25, 2012 | 01:32 AM
Ceej's Avatar
Isn't that an ignition fuse
Old Jun 25, 2012 | 04:15 AM
EmperorJJ1's Avatar
lol u act like all of them are the same
Old Jun 25, 2012 | 11:43 AM
acoutu's Avatar
DONT use that 2amp fuse on the top row. its ignition but it'll blow very easily and you'll be in trouble.
Use the fuse position 4th row down, 2nd in....i think its #16....and yes I realize you dont have a fuse in that slot currently
this ones a 15amp slot and gives you RAP power (works with IGN even when the car is off until the doors are opened)
Old Jun 25, 2012 | 12:12 PM
Ceej's Avatar
He only wants it on at night though.
OP seriously, go buy a $3 switch from autozone and just hook that up. Way easier
Old Jun 25, 2012 | 12:50 PM
yes!!!!!!!! i got it to work. thanks guys i really appreciate it!
Old Jun 26, 2012 | 12:55 AM
Ceej's Avatar
Where did you hook it up
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
