Forced Induction Turbos/Superchargers
2.2l Super Charger Project
Old Jun 8, 2006 | 02:46 PM
Halfcent's Avatar
I'm old school
Originally Posted by YellowLT
Thing is Im running a Centrigual S/C and based on that fact I believe I can safely run 8 lbs of boost on 39 lbs fuel injector (stock SS S/C) by letting the ECU re calibrate it self...
If I understand this statement correctly, you are thinking about using an ECM from a SS/SC on your LS Cobalt with an L61 engine. If that's right, it won't work.
Old Jun 13, 2006 | 05:54 PM
skydragon26's Avatar
well doesn't gm offer a 2.2 superchager kit for cavi, just get the reflash and stuff from that?
same engine right?
does this make sense?
Old Jun 13, 2006 | 08:00 PM
RedBaseBolt's Avatar
same engine right?
The kit you're thinking of is for 2.4L Cavis and Sunflowers.
It is NOT an EcoTec supercharger kit.
Old Jun 13, 2006 | 08:03 PM
SS_SC_Cobalt's Avatar
redbase, gm has a 2.2 eco s/c kit for j-bodys
I have one
Old Jun 13, 2006 | 08:06 PM
I have one
Well **** SON! I never knew that....
It's not listed on GM Performance parts...
I was going by what it said.
I type corrected
Old Jun 13, 2006 | 08:08 PM
I type corrected
pt number 1780003
it is in the 2006 gmpp cat but no picture
also GM states this warning:
his kit fits both automatic and manual transmission 2003-2005 Chevy Cavailers & Pontiac Sunfires.
This kit does not fit other GM cars that have the Ecotec engine. Programming is only available from GM for Cavalier and Sunfire models.
Old Jun 14, 2006 | 01:21 AM
Halfcent's Avatar
I'm old school
That is one of the most common mistake about that kit. It is ONLY for the J-body ecotecs. It WILL NOT WORK on the Deltas.
Lets discuss the MAF, MAP, and IAT setups. I have recieved some conflicting information. I have heard that the L61 Cobalts have a combination MAP and IAT, and I have heard they have a combination MAF and IAT. Which is it? I guess the best way to ask is, where exactly is the IAT on the car?
Old Jun 14, 2006 | 01:25 AM
YellowLT's Avatar
I know what the Maf is and I pretty sure thats what i have sticking out the side of my Air intake tube. It looks likes the MAF that was on my Olds. but what is a IAT? Oh btw project on hold till tuning avabile, i do already have the bracket fabed up along with some other parts
Old Jun 15, 2006 | 04:26 AM
smartmlp's Avatar
I think most of the time the confusion is caused by the fact that the procedure for installing the kit is talked about in a book that is supposed to be about the cobalt. If you read over the book, you notice that they make no direct comment about how the kit will not fit the cobalt (if they do I can’t find it).
This book.
Old Jun 15, 2006 | 11:54 AM
Halfcent's Avatar
I'm old school
Your right, they don't say it WONT fit the Cobalt. They also don't say it wont fit a 1973 VW Beetle. What they do say is that it WILL work on 2003-2005 Cavalier and Sunfires, right on page 26.
Old Jun 15, 2006 | 04:59 PM
  #36
smartmlp's Avatar
I dont know much about this, I have just started to read up on it, but how come you cant use a FMU like from vortech or something? Is there something im missing that the computer needs to do?
Old Jun 15, 2006 | 07:17 PM
  #37
IonNinja's Avatar
If its anything like Ford IAT's, it can actually be wired directly into the MAF. From my previous knowledge the had a separate MAF and IAT inserted into the intake and then later wired in the IAT directly into the MAF. Maybe GM took the same route?
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
ThoR294
Oct 4, 2015 08:44 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
