2.8 on stock pulley
2.8 on stock pulley
Question. I just got my order in the mail. Got 2.8 pulley, gm stage 2 belt and 60lb injectors. Now for the little story. Trying to save as much money during this upgrade as i can. That being said im thinking of doing the install myself. Only thing i know i wont be able to do is get the stage 2 belt on the engine pulleys. Once my install is done its going to a shop where its going to be tuned. If i decide to get the guy to do the whole install it will cost me $300. So what i was thinking is do the intall myself....leave the belt on and then when i bring the car to him he can swap the belts. Its no more then a 10km drive. Will the stock belt work on the 2.8 pulley for that short of time? Or does anyone know an easy way of changing the belts
why cant you put on the belt? just take off the passenger side wheel and fenderlining and you have access to do it. and i wouldnt recommend driving the car at all with 60lbs injectors in on stock tune. just do the hub, pulley, and belt at your house and pop in the injectors and harness in front of the shop
Do what I did. Put on the new pulley and belt which is really easy just make sure you don't hurt your hand pushing down on the tensioner. Then when you get to your destination put in the injectors. What ever you do, don't try to boost the car at all on your way to where you are getting tuned. Also don't forget to get colder plugs cause the stock ones wont last very long after you tune.
I drove from Southeastern WI all the way to Detroit with a 2.9 on stock injectors and got 36mpg. You will not have any problems unless you push the car with the smaller pulley and stock injectors.
well the plan was (since i dont have a pulley puller) im taking the supercharger right out of the car...taking it to the shop, he will change the pulley for free...come back to my place and put everything back on, ill take your guys advice about waiting on the fuel injectors
patooyee
Oct 1, 2015 01:07 PM
