Forced Induction Turbos/Superchargers
always bewstin
Old Apr 19, 2010 | 02:44 AM
  #51
hungryhip-ccp's Avatar
Originally Posted by jimbos'ss
good actually, had a little fun with the balt a couple weeks back, 2 1/2 hour cannonball run to the border of austria averaging 120mph........that'll test your motor lol
good to hear! im doing the valve guides on mine currently (its always something with these things)
Old Apr 19, 2010 | 06:16 AM
  #52
jimbos'ss's Avatar
yah thats why i stopped taking it all the way to 8k. don't need those kind of headaches right now.
Old Apr 19, 2010 | 08:26 AM
  #53
09blackonblack's Avatar
thanks for your help jimbo its better but not all the way fixed... im thinking im going to have to ditch the factory bpv and run an hks ssqv or something else. ive got little list of things to change today but stretching the spring on the bpv helped a BUNCH. it will get up to 0 release then cruise between 10-15 # of vacuum.
Old Apr 19, 2010 | 08:51 AM
  #54
jimbos'ss's Avatar
glad it helped man. with a custom setup like this you will spend some time working out the bugs and reconfiguring things. be patient, learn from it and have fun.
btw are you going to get the recirc kit for hks ssqv? if not and your going atmospheric, go with the tial bov.
Old Apr 19, 2010 | 08:55 AM
  #55
IF i switch i will use the recirc so i dont have to change the intake relocate the maf and a bunch of other supporting mods to have the noise i really dont care that much for.
Old Apr 19, 2010 | 09:02 AM
  #56
jimbos'ss's Avatar
makes alot of sense, have been looking into one of these myself:
http://www.xtremefabrications.com/st...products_id=27
allready have a tial flange welded to my charge pipe so it makes it that much easier for m to switch to a recirc.......i also have my own tig welder
Old Apr 19, 2010 | 09:08 AM
  #57
nice! kinda spendy though... cost more than my turbo did
Old Apr 19, 2010 | 10:55 AM
  #58
jimbos'ss's Avatar
yah but i can sell the old tial to offset some of the costs
Old Apr 23, 2010 | 07:44 PM
  #59
ok im back again... i think stretching the spring helped but cant really tell. when i shift and accelerate again im almost instantly in boost. BUT, if i let off the throttle it will blow off the pressure then be just fine. the highway it seems better but im still hitting boost
Old Apr 23, 2010 | 07:46 PM
  #60
slowswap's Avatar
So when you accelerate you build boost? Welcome to how boost is made. Engine load goes up, so does boost.
Old Apr 23, 2010 | 08:00 PM
  #61
im talking regular nice calm city grandma driving
Old Apr 23, 2010 | 08:13 PM
  #62
slowswap's Avatar
I think you're expecting this to act to much like a larger turbo. When I had my CA18 240, it would spool very fast. Small taps of gas would bring it easily up to 5 psi.
Boost a video of what it's doing if possible.
Old Apr 23, 2010 | 10:32 PM
  #63
i can text the vids. (cell phone) but on the highway it does alright just annoying it slowly creeping up then ssssfffeeewww. would lower compression pistons help?
Old Apr 23, 2010 | 10:41 PM
  #64
slowswap's Avatar
I think your missing the point.
Lowering compression would just lower power.
Old Apr 23, 2010 | 10:48 PM
  #65
wouldnt that also slow down the air leaving? im also kicking around the idea of having the turbo ported... and putting the snorkel back on the intake and stretching the bpv spring more and moving my boost gauge source i think its reading wrong... it will say 5psi of boost but you cant feel any difference in it and n/a
Old Apr 23, 2010 | 10:54 PM
  #66
slowswap's Avatar
Boost gauge needs to reference off of the manifold.
Porting exhaust side would certainly slow down spool times. Not a huge amount but it could help.
BOV springs are designed to open after a certain amount of vacuum is reached to pull the diaphragm. Stretching could cause compressor surge. What BOV and spring are you running?
This would be easier if HPT supported you so we could see your logs. I think what your describing is a normal thing.
Old Apr 23, 2010 | 11:01 PM
  #67
its the stock ko4 bpv and i know the lnf has a solonoid to control it...
Old Apr 23, 2010 | 11:02 PM
  #68
slowswap's Avatar
Might want to switch to an aftermarket.
Old Apr 24, 2010 | 10:37 AM
  #69
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by slowswap
Might want to switch to a bigger turbo.
Fixed.
Old Apr 24, 2010 | 12:22 PM
  #70
jimbos'ss's Avatar
i envy you? my turbo takes all day to spool lol
