Forced Induction Turbos/Superchargers
Belt Squeal
Old Dec 10, 2012 | 10:34 PM
blackwhine622's Avatar
Belt Squeal
So I have a belt squeal and I replaced my alternator because I thought that was causing the squeal. Turns out I wasted 160$ on a new alternator. It squeals louder then ever. I've searched the threads and cannot find a straight forward answer. I used a mechanics stethoscope and it seems like it's coming from the supercharger pulley. I realize it could also be the tensioner since it is stock and I am on the 2.8 pulley. Can someone please link me to a thread on replacing supercharger snout bearings or other solutions to my squeal?
Thanks!
Old Dec 10, 2012 | 10:52 PM
Bluelightning's Avatar
Got Bewst?
I've been where you are. Are you using the stock belt?
Old Dec 10, 2012 | 11:00 PM
CobaltSS89's Avatar
my car was squeling because my cat was clogged weird right, only did it while driving though. Not at idle. Is yours at idle?
Old Dec 10, 2012 | 11:06 PM
Yes it is the stock belt. The supercharger also sort of lags when I shift quick. Im guessing its belt slip. But yes it does it at idle and doesn't stop until around 3000 RPM's then it stops. The squeal gets quiter the longer I drive it. The colder it is the worse louder it gets. I am trying to sell it and a loud squeal doesn't help!
Old Dec 10, 2012 | 11:17 PM
CobaltSS89's Avatar
Get a stage two belt(shorter belt), adjustable tensinoner pulley, or over sized tensinoner pulley. I run a 2.8in pulley as well and have the stage 2 belt.
Old Dec 10, 2012 | 11:19 PM
CobaltSS89's Avatar
Here these should help you out.
GM ACDelco - GM Stage 2 Belt #GM-12597993
Yella Terra - Oversized LSJ Tensioner Pulley #YT-EP010
ZZPerformance - Adjustable Tensioner #ZZ-ADJTEN-CBT
Old Dec 10, 2012 | 11:20 PM
I was planning on getting the adjustable tensioner to fix the belt slip but I don't think it will stop the squeal. I think the bearings in the supercharger snout need to be a replaced.
Old Dec 10, 2012 | 11:28 PM
Got Bewst?
Alright take some soap and run it on the belt as it's running. If it goes away or gets any better first thing to try is take the belt off and flip it over so it runs on the other side. If it doesn't get any better replace your belt. If you get belt slip go with the oversized tensioner with the stock belt. I will almost guarantee your belt is garbage. I had a hell of a belt squeal battle lol.
Old Dec 11, 2012 | 08:20 PM
Already tried a new belt. Didn't fix it.
Old Dec 11, 2012 | 08:48 PM
Subd
Old Dec 11, 2012 | 09:22 PM
VapeWI's Avatar
Sounds like a supercharger rebuild is in order.
Old Dec 11, 2012 | 10:30 PM
Yes that's what I was planning on doing but I need the link to a how to thread.
Old Jan 11, 2013 | 07:37 PM
microgab's Avatar
I know its not the same issue, but when i had belt slippage, it was after 4-5k rpm. Bellow that rpm it was silent. I had a tip from a friend, to try to use a bar of soap on the inside of the belt when it was running (to put soap on the belt). Next time i tried to go wot, i went till 7k without any problem. So i changed my tensioner pulley for zzp's adjustable and now its fine
Old Jan 19, 2013 | 12:03 AM
Vander Nars's Avatar
If ur on 2.8 with the stock belt, new or old old its gonna have alot of belt slip. You need to get either the shorter gm belt or the bigger tensioner.
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
bobbob160
Sep 15, 2015 11:31 PM
