Custom Turbo Kit Installed!
#76
If you are running stock timing tables then you are screwing up your car hard core. post up your dyno numbers.
#77
Timing, very low compression and spark blow out is a big factor. My timing table was really screwed up. I was running 11 degrees max timing now with my timing tables fixed I am running 17-18 max timing.
#78
sweet u got the dyno sheet I just want to see what air fuel and all that jaz u where running. What psi where you one?
#80
#85
Josh@ottp
09-08-2015 10:18 AM
