Forced Induction Turbos/Superchargers
Finished porting my blower
Old Dec 26, 2006 | 08:37 PM
1fstss's Avatar
about how much material did you take out of it? and can you get the oil at the parts store or do i need to go to my stealership. sorry for all the questions, but im going to tackle this and i dont want to be caught with my pants down, it also looks like i can toss it on the mill at work so ill probably do that, that way i know its all even.
Old Dec 26, 2006 | 09:08 PM
euthanasia's Avatar
It was alot of material that's all I can say. I already had a couple of bottles of the oil. Not sure if you can get it from your local parts store. But yes you local stealership should have it.
Old Dec 26, 2006 | 09:22 PM
Blown 4-banger's Avatar
I would get my oil from here
Old Dec 26, 2006 | 09:48 PM
euthanasia's Avatar
Thanks for the link
euthanasia's Avatar
sent you some pics Blown 4
Old Dec 26, 2006 | 10:55 PM
spaz's Avatar
hey,euthanasia do you have any measurements of the holes?
Old Dec 26, 2006 | 11:14 PM
Cobalt_Supercharged's Avatar
Did you only port the outlet or did you port the inlet as well? I heard it is only bennificial to port the inlet and never to touch the outlet.
Old Dec 26, 2006 | 11:42 PM
euthanasia's Avatar
Spaz I do have measurements. whats it worth to you? LOL Bidding starts at $110
1fstss's Avatar
im going to order my new hub and pully, as soon as they come in im going to tear my blower off, port it and polish it
Old Dec 26, 2006 | 11:47 PM
euthanasia's Avatar
I did also port and polish half way up in the inlet. But its so minimal I cant see to much of a gain in hp compared to doing what I did to the outlet. The path the air now takes in the inlet is alot better now.
Old Dec 26, 2006 | 11:50 PM
  #36
euthanasia's Avatar
Let me know how it comes out 1fstss and good luck. You will like your car more when its done.
Old Dec 27, 2006 | 04:47 AM
  #37
I think you got it backwards. Most places don't touch the inlet and ONLY port the outlet.
Old Dec 27, 2006 | 10:36 AM
  #38
TVS_SS's Avatar
Yes.. you are correct.
The inlet is the critical part because you want to allow the rotors to fill as much as possible.. if you think about it, whatever air is sucked into the supercharger is going into the engine no matter what and changing the outlet port wont help get more air into the supercharger.
i'm quite concerned with how much the outlet was changed on that unit. especially the backflow ports.. That thing is probably quite a bit louder now..
Old Dec 27, 2006 | 10:40 AM
  #39
lsjwannabe's Avatar
why would you be concerned is there potential problem?
Old Dec 27, 2006 | 03:09 PM
  #40
HunterKiller89's Avatar
Originally Posted by euthanasia
Oxnard is in Southern California about 35 min north of Los Angels. I will send you a PM stand by.
you talkin about the oxnard around T.O.?
anyway...noob question time for me....what exactly is porting? i always hear about things getting port n polished n have no idea what theyre talkin about
Old Dec 27, 2006 | 03:11 PM
  #41
If thats the case, then why would Stegimeier (sp??) port the outlet???
Old Dec 27, 2006 | 04:24 PM
  #42
spaz's Avatar
porting means opening up the ports, polishing means to polish the ports.see the pictures at the start of the thread. The holes in the bottom of the supercharger are huge compared to the unported ones.
here is a stock pic
https://www.cobaltss.net/gallery/sho...hp?i=13360&c=3
Old Dec 27, 2006 | 04:55 PM
  #43
euthanasia's Avatar
Yes, Oxnard around T.O, Ventura, Camarillo.
Old Dec 27, 2006 | 05:28 PM
  #44
euthanasia's Avatar
By opening up the outlet ports the faster the air is moved past the rotors with less heat. And pick up more AIR volume with the port work done. If you just open up the inlet and not the outlet you have more air being compressed with possibly more heat and not much of a gain due to the smaller outlet holes. That's why its is good to do both if you can and or have the money. All I can say is that I did it and felt a differance Everyone has different set ups on there car's thus you will have different out comes with the same Mod. Some might say they felt nothing when others say it's the best thing they ever did. I'm sure if you had the car retuned there will be more of a gain.
Old Dec 27, 2006 | 07:46 PM
  #45
Looks like you took out quite bit.
Old Dec 27, 2006 | 07:47 PM
  #46
TVS_SS's Avatar
oh geez.. no comment
Old Dec 27, 2006 | 07:57 PM
  #47
TVS_SS's Avatar
Ok.. im not saying you cant do what you want. But i dont believe your statements to be very factual.
Can you tell me one thing? Do you know why those holes were placed there?
Old Dec 27, 2006 | 07:59 PM
  #48
From what I've heard they're there to decrease whine, and allow pressure back into the blower housing.
Old Dec 27, 2006 | 08:09 PM
  #49
TurboBlackBalt's Avatar
We port the outlets on the M90s as well. It results in huge gains on the Supercharged Thunderbirds. We also reshape the inlet and then polish the whole thing. Usually good for around 25-30 wheel horse. Also the charge air temps are reduced which help prevents heat soaking the ATA charge cooler on the supercoupes.
Old Dec 27, 2006 | 08:11 PM
  #50
TVS_SS's Avatar
well.. i was more or less asking the author.. but yes you are correct.
How do you regulate how fast the pressure is sent back into the blower hosuing? Size
Although.. they were mainly placed there for noise concerns..
IMO.. you'd be better off having no slots, but that would be very hard to do without destroying the housing diameter.
I do agree however, making some of the edges smoother and rounding corners will help.
