Going ZZP Twincharged- 2nd Buyer
#178
#186
#187
#191
I'd like for you to explain actually.... But I guess I'll wait.
If I recall.. I remember the OP saying that he wanted several different levels of performance.. But I forget what it was.. Perhaps that is his driving home level of performance and when he desires he can turn it up..
Zooomer will you post a dyno sheet of the car on max boost please?
#192
wtfbbq? only 254whp twincharged, what was that like 10 psi or something?
what is going on here
that would make sense, especially if the car is a dd, 300+whp and fwd would be an anoying combination for a dd,
+1 on the max boost dyno sheet
#195
is that like 'ahhhhhhhhh i know whats going on here' type of ahhhhhh?
because if you know why the car is only at 254whp, please let us know
me 2
me 2
#197
true, someone should really explain this, cuz right now, it is seriously making me doubt the abilities of this setup, granted it has made aweosme numbers in the past, it should be consistent
#199
keep in mind the fact it is a mustang dyno also, which tends to run lower #'s than dynojet.
low boost + mustang dyno would tend to make sense considering the OP only wanted around 400 for his max boost.
at any rate all you dyno # queens get a life it's about what it can put to the ground also.
