Forced Induction Turbos/Superchargers
GT2871R To big?
Old Feb 18, 2009 | 09:15 PM
pykie's Avatar
GT2871R To big?
Today i went to mount my turbo, i have it on the manifold cause i find it would be easier that way.
well 1st problem was getting it past the axel, i had to remove that, now i get the turbo up inside behind the motor and try to rotate it to fit and what do you know? it wont fit! what am i to do? i dunno what to do now.
Old Feb 18, 2009 | 09:17 PM
INFE's Avatar
which turbo mani did you get??
Old Feb 18, 2009 | 09:31 PM
pykie's Avatar
vulcan turbo
Old Feb 18, 2009 | 09:33 PM
widowedeight's Avatar
give me the turbo..... and i'll let you drive it every once and a while
Old Feb 18, 2009 | 09:37 PM
SS/SCking's Avatar
BFH time......
Old Feb 18, 2009 | 09:39 PM
pykie's Avatar
Bfh?
Old Feb 18, 2009 | 09:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by pykie
Bfh?
Big ******* Hammer. DONT do that. lol these cars are unibody and you will weaken the bulkhead
Old Feb 18, 2009 | 09:42 PM
leahciM's Avatar
big ******* hammer
Old Feb 18, 2009 | 09:47 PM
SS/SCking's Avatar
do it....
Old Feb 18, 2009 | 09:50 PM
wtpcobaltss's Avatar
sawzaw
Old Feb 18, 2009 | 09:51 PM
pykie's Avatar
on the weekend im gonna try doing it with out the turbo attached and then try the turbo, i think i have the turbine mounted the wrong way like the charge pipe side might not be far enough forward.
Old Feb 18, 2009 | 09:53 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by wtpcobaltss
sawzaw
you guys do realize this is a unibody car right? denting or cutting the bulkhead will flex the car more and crush easier during an accident
Old Feb 18, 2009 | 11:18 PM
1bdstlLSJ's Avatar
Who cares........Its all in the name of power.
Old Feb 18, 2009 | 11:20 PM
BLAZIN07SS's Avatar
I'm too JDM for you
when your insurance denies your claim due to a safety alteration, dont come crying
Old Feb 20, 2009 | 12:39 PM
Delta2.2's Avatar
pykie, post up pics of exactly what is going on
this will help us assess the sitaution.
one from below, one from above
thanks!!!
Old Feb 21, 2009 | 03:39 PM
Jn2's Avatar
Jn2
if you want to get something that wont fit in back there, i have a solution that might work
(1) undo both tranny mounts
(2) use a jack under the oil pan(use a block of wood to distribute the force)
(3) use the jack to tilt the engine more forward of backwards, this will give you more room to slide things in from the bottom or thru the top, pending which way u tilt it
we did this for my buddies sc build, we could get to the tensionor b/c of how close it was to the body, we ended up tilting the engine upwards to get to it eaiser, than put it back down and was all good
also you can remove the valve cover for some more play room up top
Old Feb 21, 2009 | 03:43 PM
elecblue06's Avatar
i dunno about the 2871 but see if you can rotate the housing slightly.. that'll definitely help out
Old Feb 21, 2009 | 03:44 PM
red06s/c's Avatar
lmao!
Old Feb 21, 2009 | 03:45 PM
slowswap's Avatar
What's hitting what?
Old Feb 22, 2009 | 05:01 PM
Kennyspec's Avatar
first of all what A/R is the housings? I hope around a .64 shoul dhave NO problems fitting it back there, i have a 2871 on my car. Only thing may be that the vulcan manifold needs the flange cut off and rotated around a bit.
Lets see some pics of the problem. PM me if you need any more help.
Old Feb 22, 2009 | 05:11 PM
Jn2's Avatar
Jn2
he got it on now, i told him how to make it fit, it fits back there, just not so easy to squeeze it in thru the top or bottom
Old Feb 22, 2009 | 07:44 PM
b_faulk75's Avatar
So what did you have to do to make it fit?
Old Mar 2, 2009 | 08:00 PM
unijabnx2000's Avatar
lol guess im too late to see if you want to trade your 71 for my 60.
Old Mar 2, 2009 | 08:10 PM
Jn2's Avatar
Jn2
i believe he is selling the turbo , check the classifieds, or go thru his thread history, ull see a FS thread on it
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
