Info/Help w/Oversize Tensioner Pulley
Hey gang, i was told that if running a smaller pulley (2.7in) that instead of going with an adjustable tensior ($100+ zzp) that you could install a larger tensioner pulley (3.5inch i believe) to help tighten the belt and help/eliminate belt slip. I wanting to know where i can purchase this, how much, pros/cons, and what is all involved in the install...hopeing for quick answers for id like to do it before the weekend. When i talked to Nate at smoothflow pulleys today he said he offers one at $50....
yea i seen the one on OTT. i just trying to figure out whats involved in install...and make sure if i have this, my stage 2 belt, a 2.7inch pulley that ill be good to go with no belt slip. ive done alot of research on here and others and it seems like everyone varies.. I've got a horrible sqeauk under my hood now, so i think its something to do with my belt..
well, i think the oversized pulley is made to be used in place of a stg 2 belt. using both might be too tight. install would probably be fairly easy though. is it a rattling or a squeaking?
not hitting your normal boost numbers (i was pushing 13psi regularly until i started getting belt slip, then it dropped down to 8psi). Its accompanied by a very distinct sound...you'd be able to guess what it is almost immediately after hearing it
patooyee
Oct 1, 2015 01:07 PM
