Forced Induction Turbos/Superchargers
Info/Help w/Oversize Tensioner Pulley
Old Feb 23, 2009 | 11:53 PM
kwest's Avatar
Hey gang, i was told that if running a smaller pulley (2.7in) that instead of going with an adjustable tensior ($100+ zzp) that you could install a larger tensioner pulley (3.5inch i believe) to help tighten the belt and help/eliminate belt slip. I wanting to know where i can purchase this, how much, pros/cons, and what is all involved in the install...hopeing for quick answers for id like to do it before the weekend. When i talked to Nate at smoothflow pulleys today he said he offers one at $50....
Old Feb 24, 2009 | 12:26 AM
HunterKiller89's Avatar
i thought either ZZP sold one or OTTP. check out their sites
Old Feb 24, 2009 | 01:45 AM
kwest's Avatar
yea i seen the one on OTT. i just trying to figure out whats involved in install...and make sure if i have this, my stage 2 belt, a 2.7inch pulley that ill be good to go with no belt slip. ive done alot of research on here and others and it seems like everyone varies.. I've got a horrible sqeauk under my hood now, so i think its something to do with my belt..
Old Feb 24, 2009 | 03:15 AM
well, i think the oversized pulley is made to be used in place of a stg 2 belt. using both might be too tight. install would probably be fairly easy though. is it a rattling or a squeaking?
Old Feb 26, 2009 | 04:00 PM
RA040424's Avatar
What might Belt slippages sound like or act like when hitting the gas? anything similar to a slipping clutch?
Old Feb 26, 2009 | 04:05 PM
mexi_loco's Avatar
kelby, I'm running a 2.7" right now on my s/c, and I didn't need to install any kind of tensioner. Stock one worked just fine
Old Feb 27, 2009 | 12:00 AM
not hitting your normal boost numbers (i was pushing 13psi regularly until i started getting belt slip, then it dropped down to 8psi). Its accompanied by a very distinct sound...you'd be able to guess what it is almost immediately after hearing it
Old Feb 27, 2009 | 12:01 AM
kwest's Avatar
no ****?? are you going to the bash?
Old Feb 28, 2009 | 12:01 AM
nherbst454's Avatar
Here's a pic of the idler pulleys I make, this is a set for the L67 but a 3.5" idler for the tensioner will look the same.
Nate
Old Feb 28, 2009 | 12:02 AM
Black SS/SC 06's Avatar
Nice I haven't seen those before.
Old Feb 28, 2009 | 04:35 PM
Jn2's Avatar
Jn2
woah those pulleys look good
Old Feb 28, 2009 | 06:22 PM
nherbst454's Avatar
Thanks, if anyone's interested feel free to pm/call/email me!
Nate
Old Feb 28, 2009 | 06:23 PM
Jn2's Avatar
Jn2
i may be but i need to figure some things out, wether i want to change from turbo build to supercharge instead
Old Mar 2, 2009 | 10:12 PM
kwest's Avatar
Nate, from my understanding the stock pulley is 2.5inches, so the ideal oversized to help belt slip would be 3inches...but yours are 3.5inches..???
Old Mar 2, 2009 | 10:26 PM
i think the 3.5" ones are for the M90 cars...not for us. He can make any size pulley anyway, so he can make a 3" idler pulley
Old Mar 3, 2009 | 11:14 PM
nherbst454's Avatar
The L67 uses one 3" ribbed, one 3" smooth, and one 3.5" smooth so I have whatever you want in stock. One member is running a 3.5" smooth if I recall correctly.
Old Mar 4, 2009 | 11:39 AM
kwest's Avatar
http://www.ottperformance.com/Cobalt...duct_info.html
Old Mar 4, 2009 | 12:15 PM
^^ yea....whats the question/confusion?
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
