Forced Induction Turbos/Superchargers
Jn2's turbo build thread
Old May 9, 2008 | 04:17 PM
  #51
Sw4y1313's Avatar
Originally Posted by 2K5SS/SC?
I think they are right about the same. I think that is the 6th gen 16G which is used on the newer EVO's, but don't quote me on that though. The EVO III is supposed to put 550cfm at 14.7 psi and it's supposed to spool faster due to the lighter wheel. I know that when I had my small 16g up to 15psi it was crazy. My buddy that is breaking in the new clutch and turbo for me since I'm still deployed said that the car is pulling crazy hard at 12psi and he isn't even fully reving it out because the clutch is not fully broke in yet. He has driven it many times himself, so if he's says it's pulling hard I believe him.
yeah but thats also at sea level. im at 2500-2700ft above. so my pressure ratio will be different. Also, the garret calc's put into play pressure loss from an FMIC. so i could probably make 350whp on 20-22psi.
Do you know the specs on the hot side? i hope its like a .63 AR so i dont choke at the top.
Old May 9, 2008 | 04:35 PM
  #52
2K5SS/SC?'s Avatar
7 cm 2 which is the equivalent of a .49A/R. You shouldn't choke up top as many DSM guys have made 400+whp with this turbo at around 24-25psi.
Old May 9, 2008 | 05:30 PM
  #53
Sw4y1313's Avatar
sweeetttt. <3 u 2K5, thanks for pointing out a great turbo for a great price.
  #54
IonNinja's Avatar
for example. 40lb/min of air about 380bhp worth of air.
I understand how the compressor map is supposed to work
what I don't get is the math that you're doing that makes 40lb/min = 380hp
Old May 10, 2008 | 04:50 AM
  #55
2K5SS/SC?'s Avatar
Your supposed to put "no homo" by a comment like that! Glad you like the turbo. It's just a great bang for the buck and a highly overlooked turbo. Most people go too big for their application and lose power down low because of lag. With a properly sized turbo lag is very minimal, and it will create a large power band that doesn't drop off.
Did you look at Garrett site and their explanation on how to do the math yet? If not you should really check it out. It will help you understand even better.
Old May 10, 2008 | 04:51 AM
  #56
Jn2's Avatar
Jn2
i got my new boost gauge in, got the tinted series from
www.prosportgauges.com, tinted series, light up white, and turns red when i go over the amount of boost i have it programed for, also finally got around to ordering the IC piping and the BOV with adapter pipe
Old May 10, 2008 | 05:58 PM
  #57
mike25's Avatar
sounds like a nice hauge...how much? there a link for them i couldnt find the tinted series
Old May 10, 2008 | 08:37 PM
  #58
Jn2's Avatar
Jn2
http://prosportgauges.com/amber-whit...ost-gauge.aspx
thats the link to the one i have, its the electirc boost gauge
Old May 10, 2008 | 09:30 PM
  #59
mike25's Avatar
thats a good price...how reputable are these gauges?
Old May 11, 2008 | 12:35 AM
  #60
Jn2's Avatar
Jn2
dunno, but they look nice
Old May 11, 2008 | 01:11 AM
  #61
mike25's Avatar
well make sure you post up some pics of the istall and let me know how they are...i like because the match the stock 2.4 speedo/tach cluster...i may go with them if they turn out good
Old May 11, 2008 | 01:18 AM
  #62
Jn2's Avatar
Jn2
i can wire it up later ont his week, to get it to power up...needle w ont do ****, but i can atleast power it to turn on
Old May 11, 2008 | 01:21 AM
  #63
mike25's Avatar
thats good....you gettina double or tripple pod?
Old May 11, 2008 | 02:03 AM
  #64
Jn2's Avatar
Jn2
most likely going to just buy a ss/sc pillar, im selling the 2 gauges i already have, the autometer boost and oil psi gauges, id ont want them, andi already have my prosport on sitting my closet, so i dont need 2 boost gauges
Old May 11, 2008 | 02:18 AM
  #65
2K5SS/SC?'s Avatar
Gauge looks neat. Interested to see how it works out for you.
Old May 11, 2008 | 10:48 AM
  #66
mike25's Avatar
how much are you selling the autometers for?
Old May 11, 2008 | 04:06 PM
  #67
Jn2's Avatar
Jn2
40/each, or 70 for both
boost and oil psi, both brand new
Old May 11, 2008 | 09:59 PM
  #68
mike25's Avatar
are they electronic full sweeps or just mechanical?
Old May 11, 2008 | 10:36 PM
  #69
elecblue06's Avatar
that boost gauge looks pretty awesome..
Old May 12, 2008 | 06:07 AM
  #70
Jn2's Avatar
Jn2
the boost gauge is mechanical, and the oil psi is electrical(the ones im seling are in the pics in my first post, the autometers)
just picked up a set of lsj injectors too, 50 bucks, and he threw in the harness for free
ps-i think the turbo is set to .8 bar, somewhere in that area, which converts to 11.6psi
Old May 12, 2008 | 10:56 AM
  #71
elecblue06's Avatar
almost there man almost there
Old May 12, 2008 | 12:02 PM
  #72
Sw4y1313's Avatar
Nice dude, sweet deal on the injectors. What else do you have left to do?
Old May 12, 2008 | 04:17 PM
  #73
mike25's Avatar
so your saying the oil psi is full sweep electrical?
Old May 12, 2008 | 06:17 PM
  #74
Jn2's Avatar
Jn2
i olny need the turbo manifold, and the tune, when the manifold gets here i will fab the dp and route all the piping, so that manifold is the only thing holding me back from having the kit done, after that there would only be the tune left, and the gauge is electric, comes with the sending unit, you just plug the unit somewhere on the plug, and than a wire runs from the sending unit to the back of the gauge for the signal
Old May 13, 2008 | 08:37 PM
  #75
Jn2's Avatar
Jn2
intercooler is gay, i made another attemp to mount it, but i coulndt drill thru the collision bar in the front, the impact bar...its to dam hard, my drill barely grazed it, so i will have to weld, i will wait till my piping gets in though, should be here thursday, but i will work on it saturday as i am off, so by saturday i should have the IC piping and the BOv with the BOv adapter, i went with a knock off type rs
