Forced Induction Turbos/Superchargers
methanol injection?
Old Sep 7, 2011 | 11:30 AM
fastscion's Avatar
methanol injection?
Hi
I’ve a 2006 Cobalt SS S/C with the mods listed below
But I’m having the IAT2 to high between 175 to 185 and is looking into going for methanol injection what methanol setup do you recommend me to use to get the best performance out of the car? Or maybe you have another better option?
Thanks in advance
Old Sep 7, 2011 | 09:09 PM
87gn06gto07irl's Avatar
I recommend you check your i/c pump first
Old Sep 8, 2011 | 06:32 AM
06cobalt racer's Avatar
yeah replace pump first
Old Sep 8, 2011 | 08:17 AM
fastscion's Avatar
i've checked the pump and the pump is ok
Old Sep 9, 2011 | 09:42 PM
johnladow07's Avatar
I'd recommend Alcohol Injection Systems. Rodney is awesome and will walk you through everything and anything if need be. I have 3gph nozzle running 50/50 mix and it does the trick. I have a similar setup to yours.
Old Sep 9, 2011 | 10:44 PM
fastscion's Avatar
ok thanks for your reply
what's your IAT2 temps now?
1/4 mile time?
with the alcohol system
Old Sep 10, 2011 | 06:47 PM
In the past 135* IAT2 with 90*+ IATs in the summers. These numbers are after WOT runs. Regardless the only time my IAT2 have ever been close to what you stated was when my IC pump failed.
Don't have any track numbers for you.
Old Sep 11, 2011 | 09:16 AM
fastscion's Avatar
ok
my numbers are during WOT in the 3rd gear after the WOT the IAT2 is around 160
Old Sep 11, 2011 | 09:19 AM
Sylver01's Avatar
My IAT2's used to be that high with less mods than you. My IC pump was dead.
Old Sep 12, 2011 | 03:38 PM
devilsown's Avatar
Pretty sure AIS is out of business.
take a look at our systems, I know we have some of the best parts because others are always coping our ideas
Your numbers do sound a tad high but remember it has been nuts hot. With methanol injection you can easly drop your temps another 100 degs.
Old Sep 12, 2011 | 03:41 PM
BYT*SS*TURBO's Avatar
Your pump is def shot, that is way high.
+1 for AIS Meth Kits. Very simple hookup and a nice setup
Old Sep 13, 2011 | 01:58 AM
Old Sep 13, 2011 | 02:02 AM
100% METH's Avatar
Just spoke w/ AIS recently. AIS no longer frequents css that's all...
Old Sep 13, 2011 | 02:05 AM
100% METH's Avatar
Originally Posted by fastscion
Hi
Thanks in advance
Your iats should be no where near that even on a stock intercooler setup using the m62 & 2.7 pulley. 140s tops... on a 80* day
I'd drain your lines, take off your manifold and clean out the cores from possible blow by these cars like to get.
refill, bleed the system and try again.
otherwise... AIS, devilsown, sno, cooling mist... they all provide the same end result.
Old Sep 13, 2011 | 03:58 PM
jonnymerk's Avatar
I'll be going devil's own pretty soon and should be posting up picks of install. Will be good for most up until the direct port portion.
Old Sep 14, 2011 | 02:58 PM
busa4's Avatar
how did you check the pump? a pump may work but not flow enough volume.
Old Sep 15, 2011 | 10:30 PM
fastscion's Avatar
ok thanks for all the feedbacks
the pump was dead i've connected it directly on the battery to test it and it was dead
i just bought a new pump and hooked it up
when the pump was dead the temps went up to 240 after hooking up the new pump its like this now
Old Sep 15, 2011 | 10:48 PM
fastscion's Avatar
can you explain more into details about "clean out the cores from possiblle blow" ?
i've tried a lot of things to get the temps lower but didn't succeed to get it better then 175
06blackg85ss
83
Jan 18, 2017 04:35 AM
SlowSaturn
Sep 28, 2015 11:03 AM
roadrunner132
Sep 16, 2015 09:13 AM
Bluelightning
Sep 8, 2015 05:18 PM
Macgyver2484
Sep 2, 2015 05:44 PM
