not building boost with 2 step
just as the title says. i have done a boost leak test and it is holding boost fine. also the car will break boost fine. any idea why i am not building boost while i 2-step before i launch?
you have the WOT box cause i beleive you are a turbo swapped lsj...mine does the same thing, it wont build boost on my turbo swap. but when i was supercharged it was build 10lbs of boost at like 3600rpms...so i dont know why it doesnt work with the turbo.
you would build boost reving the supercharger?
im not saying i use it. im not even supercharged anymore. i just have the WOT box. so why not make sure everything is working and try it out. but it will build boost lol. i will say i have used it and knew it would be useless, but it was funny. i only use it for the no lift shift anyways
I believe you need to tune for better results with building boost on the 2 step. If you retard the timing it will create much higher egt's but it will help spool the turbo creating some boost at the line.
Your turbo needs to have a load on it to build boost, ( I say load to make it easy, lol) Just free rev exhaust gas will not spin the turbine fast enough. How many rpm are you 2-stepping the car at. If you raise wot box up high enough you will see some boost but not very much. If you make the correct changes to your high oct timing chart you can use the wot box to stabilize your rpm and stay in the correct cyl. airmass cells and you will build as much boost as you want. You will need to do some logs to figure out where your cyl. airmass is at while you are on the 2-step. You should learn how anti-lag works before you start getting carried away!!
When my car was a 5 spd. I could could control my boost on anti-lag from 5-30psi pretty easily.
