Forced Induction Turbos/Superchargers
plugging silencer holes
Old Mar 16, 2009 | 09:16 PM
2FaSSt4U's Avatar
Originally Posted by ssyellowss
thats right, if the people in the car next to me dont go deaf from the whine, then its a fail.
plugging them has no negative effect unless what you plug with interferes with the rotors(bad juju) or the material used sticks too far out to disrupt airflow. granted JBweld doesnt tend to hold but since discovered everyone is told to stay away from it. to date i havent known of quicksteel failing
The whine you pick up from plugging the silencer holes is not quite that loud lol, it is a noticeable difference though and only under throttle.
Old Apr 13, 2009 | 09:27 PM
startingline05's Avatar
so what steps would u take when plugging the holes with quicksteel?
Old Apr 13, 2009 | 09:31 PM
Jn2's Avatar
Jn2
plug them with quick steel
go back and sand them smooth, i went back and did it 3 times bc everytime i thought i sanded it smooth, and put the blower back together and spon'd the pulley it would stop and wouldnt turn bc it was hitting the quick steel on the inside, so it has to be a perfect sanding on the inside, not so much on the outside though, but it takes a few hrs to get done right
Old Apr 13, 2009 | 10:36 PM
schamsy's Avatar
No sanding required if done correctly.
Old Apr 13, 2009 | 10:43 PM
it sounds like too much work and too much noise for just alittle extra whinning sound
Old Apr 14, 2009 | 12:58 AM
ssyellowss's Avatar
lol i know. i was over exaggerating. i would like it louder tho. a quieter exhaust with a louder supercharger is teh sex
if you have the supercharger off already, ie: pulley replacement, porting....., then its really not a lot of work at all. sanding isnt necessary unless you get sloppy with the quicksteel. i'd probably smooth it anyway being a perfectionist lol.
Last edited by ssyellowss; Apr 14, 2009 at 12:58 AM. Reason: Automerged Doublepost
Old Apr 14, 2009 | 01:26 AM
Jn2's Avatar
Jn2
yeah i tried to keep it smooth i taped the other end to keep it from going int o far, but when by the time i noticed that it wasnt going to be perfect by hand the **** was already half dry
Old Apr 14, 2009 | 01:38 AM
ItalianJoe1's Avatar
In theory, if you pre-heated the housing and tacked the plugs in very carefully you could do it without warping the housing.
Old Apr 14, 2009 | 02:02 PM
wallyboy724's Avatar
any body got a video of what it sounded like before and after? and pics of the install?
Old Apr 14, 2009 | 02:22 PM
stoon_cobalt_colby's Avatar
im also very interested in this before i get it done
Old Apr 14, 2009 | 08:22 PM
  #36
harryresh's Avatar
where is this stated? if i didnt delete my emails, i had a conversation with an eaton engineer who explained to me the purpose of these holes.
it is stated right in the middle of the first paragraph
Old Apr 16, 2009 | 11:38 AM
  #37
Dragonsfire12345's Avatar
I plugged mine.... but my cars not running.... I believe I still have an intake leak somewhere and will work on it tomorrow.
but...
from where it runs... I can tell there is a difference.
Old Apr 17, 2009 | 06:30 PM
  #38
Frew's Avatar
plus taking the supercharger off is so easy, i can take mine off in 15 mins
Old Apr 17, 2009 | 06:41 PM
  #39
coopn8r's Avatar
This should be a Use at your Own Risk Mod.. Plenty of people use quicksteel and everything works out and THEN.. You have people like me where the quicksteel failed and went into there intake manifold.. I found 1, but the other had gotten destroyed by the Laminovas..I know how metal all over my intake manifold and in/on my Laminovas..
Like I said, Use at your own Risk.
Old Apr 19, 2009 | 11:42 PM
  #40
Dainslaif's Avatar
Weren't you the guy who didn't properly prepare the surface of the blower and only let it dry a few hours before starting up your car?
I have 6k on my plugs in my SC, with no discernible wear. I'll put up pics if I ever get them from my friend.
Old Apr 20, 2009 | 09:24 AM
  #41
red06s/c's Avatar
I dont understand whats the problem with doing this. You Clean it, and plug them pretty much. Ive got alot of mines on mine and they look just as good as the day i put them in. Im also running meth.
Old Apr 20, 2009 | 11:59 AM
  #42
coopn8r's Avatar
No, that must be someonelse.. I sanded and roughed up the surface very nicely and let the Quicksteel dry for a considerable amount of time.. I didn't even put on my blower until the next day.. I do not know why it didn't take and I wouldn't have ever known had I not taken off my blower when I was tearing apart my engine to swap pistons.
It wasn't my negligence. Unsure why it happened, I'm just saying.. It doesn't work 100% of the time. There are arguments on both sides.. I'm just letting people know what happens when the quicksteel falls out or isn't put on properly for that matter.
-Matt
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
Slick_Nick
Sep 28, 2015 09:15 PM
