Forced Induction Turbos/Superchargers
Q's bout boostin an '06 cobalt
Old Sep 4, 2007 | 10:27 AM
orangesurfcobalt's Avatar
Whats up every one So i have a million 's bout this. I owe a built and boosted civic i feel i know alot bout these set ups but my Gf has an '06 cobalt. We wanna boost but i have so many things i don't know about with her car. On mine i had to re chip my ecu but i don't see much info on that for hers i had blown my motor due to a bad tune and now i'm fully built my (motor was only good for bout 10lbs stock how bout the cobalt?) but then i ran into trouble, my clucth can't hold tha power and i'ver broken two sets of axles What can i expect to run into with her car? i wanna have bout 300 hp but reliable cause it's her car . any help . . . .
Old Sep 4, 2007 | 10:29 AM
07SSCharged248's Avatar
What kind of Balt??
Old Sep 4, 2007 | 11:08 AM
kovich14's Avatar
/\ /\ /\ /\ Agreed. Both motors will be dynamically different under boost, we need to know what motor
Old Sep 4, 2007 | 12:01 PM
Sw4y1313's Avatar
Well dont look at it in boost. You want 300hp, whp? I take it its not an SS/SC. So either she has a 2.4 or 2.2. The 2.2 is good for about 220whp give or take. Hahn has their 2.4 Solstice up to what 320whp? If she has the 2.4, you can make 300bhp with a mildly sized turbo fairly easy. If she does have the 2.4, your going to need HPTuners to tune the car. If its a 2.2, you will need to run a piggyback as of right now. AEM FIC or Perfect Power's SMT-6 have been proven to work. If you want 300hp out of a 2.2, you will need to buy new pistons and rods at the least. That will make the engine good for 400whp.
Old Sep 4, 2007 | 02:32 PM
it's a 2.2 non sc
Old Sep 4, 2007 | 04:23 PM
Sw4y1313's Avatar
Well if your girl wants a fairly quick boosted car, for cheap, i would go with a used M62 setup off an SS/SC(M62, intake manifold, Heat Exchanger). It would get her to about 200whp+/-, keep the car fairly reliable and you could have all the parts for about $1500 give or take. Tuning would require a AEM Fuel/Ignition Controller which is about $400-450.
Old Sep 5, 2007 | 06:10 AM
Well she wants to spend bout 5-6 grand . . now my car runs low 12's on street tires and ost my buddies have 12 sec cars . . i know she's gonna wanna be with us one day but for now she just wants to be " faster" i've seen a kit from Hahn that looks pretty good but i know with mine i spent alot of money i didn't need to because of buy wrong parts and replacin parts i should have got in the begainin.
Old Sep 5, 2007 | 10:49 AM
Sw4y1313's Avatar
I would recommend getting the Hahn kit then if she is looking to spend 5-6 grand. With 5 grand you could pick up the Hahn kit($3300?), Boost/AFR Gauges($400ish), Diamond Pistons w/ rings($475), eagle rods($300), Cometic Head Gasket($80), and Stage 2 clutch w/ fidanza flywheel($650). That right there can get her low 13's maybe high 12's running higher boost. Problem is, your gonna need to have the car retuned by a SCT Dealer. As of right now i dont think you can do your own SCT tuning(hopefully that will change here soon). Oh forgot, you will need 60lb injectors(about $250 w/ harness?) cuz the 34's wont handle 300hp. That should get her into lowww 13's, maybe 12's if she can really drive or get slicks.
Looks like a total of about $5455 give or take. I quoted high just to be on the safe side. If you can do all the engine work yourself, which you should be able to with the GM Build book, you wont have to worry about labor.
Old Sep 6, 2007 | 04:26 PM
your amzing with the info. my buddy has a boosted 98 mustang gt he's goin with a sct tune and a hand held tuner also I'll try to get info on all the tunni from him. . .you guys are sure pointin me in the right direction and been more help then i can say. One more question is bout the tranny and axles??? and Axles also does this car have any type of lsd? do i need to improve any thin in the tranny to hold to gether this kind of power?
Old Sep 7, 2007 | 04:30 AM
2.0freakotec's Avatar
really u ran 12's on street tires i smell bull **** prove it low 13's but not 12;s sorry dude get it right
Old Sep 7, 2007 | 09:04 AM
Ok bout the last post . . .trust me I'm not here for a my car is cooler or faster contest. I was just makin a point bout how for most people just addin a sc would be enought but I know if she is doin cruises with us then she'll wanna keep up gradin her car like we have and the best way I see that is close to limit less would be Turbo. Now if you really wanna talk bout my car I'll give you my myspace and You can see a few picts of it and I'll be more then willin to tell you all about it to prove it.
Old Sep 7, 2007 | 09:12 AM
alleycat58's Avatar
NO LSD on the 2.2s, but there's one available from Quaife for about a grand. You have to make sure it's for the 2.2/2.4 Cobalt tranny, the 2.0 SS/SC tranny is completely different. Axles are a weak point but there are Driveshaft Shop stage 2 axles available for $700 give or take.
As for tranny, assuming she has a manual since you're looking at the Hahn kit (manual only). I would say the clutch would be your main concern at those power levels. Not a whole lot else available for the manuals as far as the tranny itself.
Old Sep 8, 2007 | 03:21 PM
Sw4y1313's Avatar
Theres your answer right there. You would need the LSD installed, it doesnt come factory. but im not 100% positive that those axles will fit our tranny. They are made for the F35 tranny thats in the SS/SC. I will be going to the dealer to compare both axles to see if they will fit the F23(2.2/24 manual tranny). Unless someone has already confirmed they will work.
BTW, your welcome =P if you have any questions just ask man! i love sharing knowledge.
Old Sep 8, 2007 | 05:00 PM
HunterKiller89's Avatar
sway, im not positive, but a couple people told me they are the same axles...which is why they break so easily. they were made for a 2.2
Old Sep 8, 2007 | 05:24 PM
Sw4y1313's Avatar
Sweet, if we can get a 100% confirmation then i know what axles im getting =P
Old Sep 9, 2007 | 06:54 AM
kinda random sway...but u get +rep....i never give you rep and you deserve it for bein helpful
Old Sep 10, 2007 | 12:26 AM
Sw4y1313's Avatar
Thanks buddy, i appreciate it. Rep is cool, but the positive comments are even better =P Thanks again, +rep back to ya.
Superslowbaltt
Sep 22, 2015 10:24 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
