Forced Induction Turbos/Superchargers
SMG's first...REMOTE MOUNT TURBO TWINCHARGED LSJ!!!
Old Mar 23, 2010 | 09:31 PM
  #251
slowswap's Avatar
Originally Posted by KangolRiot
341whp and 308wtq
This is the dyno compared to my 2.6 just supercharged. blue is the 2.6 and red is the twincharged
Doesn't even look like the supercharger is helping do anything. Should have just went turbo and probably had an even quicker spool up.
Old Mar 23, 2010 | 10:33 PM
  #252
elecblue06's Avatar
exactly what i was thinking.. wheres what's his names GT35R turbo dyno when he put down like 350 whp i'd like to see them side by side
none the less piping and everything looks much cleaner
Old Mar 24, 2010 | 04:34 AM
  #253
Maxim_X's Avatar
You can lay that graph over mine and see what the difference is. His spool is much quicker. See if Fred can overlay them then post it up.
Old Mar 24, 2010 | 04:57 AM
  #254
freakta's Avatar
i bet that this is a blast on the street
Old Mar 24, 2010 | 08:05 AM
  #255
i went for a ride in the first one and all i can say is weeeeeeeeeeeeeeeee lol
Old Mar 24, 2010 | 09:52 AM
  #256
ebristol's Avatar
That is because he is on stock pulley. You can see in the graph where only the Supercharger is making boost. Then the turbo starts to spool.
They should put the 2.6" back on there and try it again!
Old Mar 24, 2010 | 12:33 PM
  #257
Stiner's Avatar
yeah it sort of falls off inbetween. looks like with the current set up you would be better off with straight turbo
Old Mar 24, 2010 | 01:02 PM
  #258
freakta's Avatar
when your cruising down the highway minding your own buisness and a car runs by you, this setup will run away from a turbo only setup, thats the beauty of having both
Old Mar 24, 2010 | 03:44 PM
  #259
Stiner's Avatar
it doesnt appear that way from the dyno though
Old Mar 24, 2010 | 05:52 PM
  #260
talking from riding in their first twincharged car that thing got up and went like crazy.
it had a N/A style pull to it all the way from the bottom till redline. it was great
Old Mar 24, 2010 | 06:24 PM
  #261
Stiner's Avatar
nice Dyno's dont tell the whole story for sure
Old Mar 24, 2010 | 06:50 PM
  #262
slowswap's Avatar
A proper turbo setup making the same power, will beat this setup. The dyno graph doesn't lie, well it can, but they clearly didn't with this graph.
ZZP's setup clearly shows a better torque curve for the twin charge setup. I have feeling something is not setup properly to take advantage of the supercharger. Your graph looks more like a turbo only graph.
Compare them all.
Old Mar 24, 2010 | 08:38 PM
  #263
Maxim_X's Avatar
I run the same turbo. I dynoed @ the same place. Lay his over mine and you will see it clearly has more early HP.
Old Mar 25, 2010 | 12:45 AM
  #264
slowswap's Avatar
GT3582r as a remote mount on a 4 cylinder? I would like to see the graphs overlayed if they were both run at the same PSI.
EDIT: And if you were both running same PSI elimanating, we can already see which setup is more efficient considering you've broken 400 whp and he hasn't.
Old Mar 25, 2010 | 01:00 AM
  #265
elecblue06's Avatar
i'm trying to find a graph to overlay .. but i can't find it .. post it up maxim
Old Mar 25, 2010 | 04:26 AM
  #266
Maxim_X's Avatar
I'm not remote mounted and I run more boost. Personally I'd say my setup is more efficient, making more power in the top end, but, he makes more power over the curve.
Old Mar 25, 2010 | 10:45 AM
  #267
elecblue06's Avatar
post up your graph from when you dynoe ld like 351 or whatever
Old Mar 26, 2010 | 03:32 PM
  #268
Slammed07's Avatar
So what did this set up actually run you of you don't mind me asking. I think there's more work to be done here but I think this could turn out to be a great seat up in the end!
Old Mar 27, 2010 | 09:54 PM
  #269
j27-2's Avatar
whats the cost?
Old Mar 28, 2010 | 09:41 AM
  #270
Dayta's Avatar
Call smg and talk to Fred about cost
Old Mar 28, 2010 | 05:52 PM
  #271
Maxim_X's Avatar
Next time your in the shop do you wanna post his dyno over mine?
And where is that dyno vid you took of my car?
Old Mar 29, 2010 | 08:55 PM
  #272
Slammed07's Avatar
I talked to Fred today about doing this on my car. He said he's gonna be doing another kit soon on a lowered car to see he'd have any issues. He said he doesn't think he will the turbo is tucked up in there pretty good, the only area he might is the pipe that runs over the passager side axle.
He said there thinking the kit will be around 3grand and should be up on the site soon!
Old Jun 3, 2010 | 09:14 PM
  #273
ebristol's Avatar
So what is the latest on this?
Old Jun 3, 2010 | 09:33 PM
  #274
elecblue06's Avatar
probably just more fail
Old Jun 3, 2010 | 09:40 PM
  #275
freakta's Avatar
fail? it seemed to work fine
