the turtle turtles trubo build lol
alright the build is going slow.. ttryna make sure everything is perfect.. besides im not getting my turbo til wens so i got plenty of time lol
cylinder 1 honed
all cylinders honed
my honing tool
resurfaced the block with a wiz wheel
block painted
tape removed
dropped the crank in
cylinder 1 honed
all cylinders honed
my honing tool
block painted
tape removed
the girdle (dirty)
the girdle (clean)
the block with the lower crankcase on (girdle)
my head came back from the machine shop
dam wat clutch were u running ?
Last edited by *S!CC_R@c!NG_TURTL3*; Dec 9, 2009 at 07:19 PM. Reason: Automerged Doublepost
exedy hypersingle. it turned out to be a bad throw out bearing and clutch master but i just changed everything while it was apart. resurfaced flywheel, new flywheel bolts, new clutch, new TOB, new clutch master cylinder. and i sold the exedy locally
spec stg3+
how much to resurface the flywheel ? is it recommended ?
Last edited by *S!CC_R@c!NG_TURTL3*; Dec 9, 2009 at 07:30 PM. Reason: Automerged Doublepost
when you get a clutch get a stage 3 or 4 form clutch masters... exedy only has a stage 1 and 2 and stage 2 is only rated for 279tq =[ how much power you looking for from this build?
that was me hahaha
that was me hahaha
Last edited by CobaltLs_14; Dec 9, 2009 at 07:34 PM. Reason: Automerged Doublepost
just gotta learn how to install the progessive controller looks kinda hard haha
haha yeah money goes quick when doing these projects. the progressive controller is actually very easy. you just wire it into the MAP sensor. its just a one wire tap. you are going to need a map sensor that can read boost though since yours does not
soo now i need a map sensor ? where can i get one ?
